I receive the message:
An unexpected error occurred:
There were too many requests of a given type :: Error finalizing order :: too many certificates already issued for exact set of domains: wicz.net ,www.wicz.net : see https://letsencrypt.org/docs/rate-limits/
I was experiencing problems on the server, so there have been countless attempts.
Can the unlock be done?
Hi @rbogdanowicz
there are a lot of certificates:
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=p:d2ljei5uZXQ6ZmFsc2U6ZmFsc2U6OkVBRT0&cert_search=include_expired:false;include_subdomains:false;domain:wicz.net&lu=cert_search_cert
Where are these? Isn't it possible to use on of these? Some have one, some have two domain names.
If you have trouble to create a certificate, first use the test system. It has it's own limits.
rbogdanowicz:
No. Normally, create one certificate, then use it 60 - 85 days, then create the next.
Hello @JuergenAuer ,
Thanks for you reply!
I just know how to install via command:
sudo certbot --apache -d wicz.net -d www.wicz.net
Is there another way to reuse the previous certificates?
Thanks again…
JuergenAuer:
certbot certificates
No certs found.
I created a new droplet =/
Then you have to wait one week.
Letsencrypt certificates are free, but creating certificates requires resources. Resources are always limited, so the number of certificates is limited. Revokation wouldn't help.
