The requested apache plugin does not appear to be installed - Apache - python-certbot-apache IS installed
This seems to be a FAQ, but the usual remedies don’t work for me…
Server
Debian 9.1 (Stretch) 32 bit
Apache 2.4.25
Installed
sudo aptitude install certbot python-certbot-apache
What’s not working
I already have certs in place, generated before the upgrade to Debian 9.1.
Since the upgrade, I can no longer renew the certs, and when I run sudo certbot -vvv --apache, I get
Root logging level set at -10
Requested authenticator apache and installer apache
No candidate plugin
Selected authenticator None and installer None
Log:
2017-09-04 09:48:15,148:DEBUG:certbot.main:certbot version: 0.17.0
2017-09-04 09:48:15,148:DEBUG:certbot.main:Arguments: ['-vvv', '--apache']
2017-09-04 09:48:15,149:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2017-09-04 09:48:15,164:DEBUG:certbot.log:Root logging level set at -10
2017-09-04 09:48:15,165:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2017-09-04 09:48:15,166:DEBUG:certbot.plugins.selection:Requested authenticator apache and installer apache
2017-09-04 09:48:15,166:DEBUG:certbot.plugins.selection:No candidate plugin
2017-09-04 09:48:15,166:DEBUG:certbot.plugins.selection:Selected authenticator None and installer None
Troubleshooting
I’ve tried uninstalling and reinstalling the certbot and python-certbot-apache packages, to no avail.
I do see the apache plugin installed in /usr/lib/python2.7/dist-packages/certbot_apache. The built-in plugins are in /usr/lib/python2.7/dist-packages/certbot/plugins/. Could this be the issue?
It looks like you may have added certbot twice.
Package “python-certbot-apache” should already include certbot.
Package managers will resolve such things, and aptitude certainly does. Certbot is installed only once.
Hi @paour,
The log shows that you are using certbot 0.17.0 but Debian Stretch packages certbot version 0.10.2. Did you install it from other repository?.
Cheers,
sahsanu
This was indeed the issue, thank you for pointing me in the right direction!
I had both the Debian version and the pip package installed. Removing the pip version caused me to experience this error, so I bit the bullet and (contrary to the instructions) removed the Debian package for certbot and installed only the pip version:
sudo pip install certbot certbot-apache
That worked fine.
I may have misunderstood your post to mean that sudo aptitude install certbot python-certbot-apache would cause certbot to be installed twice.
You were correct in indicating certbot was installed twice: once by apt/aptitude and once by other means (probably as I tried various ways to resolve missing dependencies).
