In production mode, I get the certificate as before.
But using staging mode I started getting an error in the very last request, when all checks are done and all that is left is to get the certificate from the server.
Problem connecting to server (post for ; curl returned with 3)
+ Requesting certificate...
2023-07-11 18:26:10 - le error: Problem connecting to server (post for ; curl returned with 3)
+ Checking certificate...
+ error: failed to run x509 -text (Exitcode: 1)
Details:
Could not read certificate from <stdin>
I use my finalized dehydrated script.
But on the latest version of dehydrated 0.7.1 the problem is also reproduced if you change the url to staging/ in the settings.
dehidrated 0.7.1
https://acme-staging-v02.api.letsencrypt.org/directory
What exactly is the reason for the servers not working or another protocol change?
How should I modify the last call of dehidratet to make it work or send me a link to the documentation where this change is shown or to a fix in your certbot.
