Test Validation Works, Cert Request Fails in FileMaker Pro
FileMaker Server 22 now has Let's Encrypt baked in, but I'm having problems with it that Claris hasn't been able to solve. Across my domain with a particular hosting provider, I cannot get a single SSL issued. The test validation passes, but the actual SSL fails to issue, giving " Certificate Request Failed. Failure / timeout verifying challenge passed"
Port 80/443 are both open in Windows Firewall, and I can run curl -i http://EXAMPLE.DOMAIN/.well-known/acme-challenge/test.txt from any machine outside my network and it returns 200/the contents of the text file, so I know the port is open. But when I go to letsdebug.net and run a test I get "Connection reset by peer".
The hosting provider swears there's nothing upstream blocking port 80, but I'm no longer confident that there's nothing blocking either the port or let's encrypt's servers themselves. Does anyone have further ideas/tests I can run down before going back to the hosting provider?
*.portagebay.com
FileMaker's "Request" function
"Certificate Request Failed. Failure / timeout verifying challenge passed"
FileMaker Server 22.0.2.204
Windows Server 2019
private cloud
no
Are you trying to get a cert for *.portagebay.com? Because you'd need to use DNS validation for that, not HTTP.
No, sorry I should've been clearer. I'm trying to issue multiple for different subdomains and used that notation to represent such. I've tried to issue them to:
All failed, but when I tried on a couple AWS instances using identical SW versions and port settings, I was able to get it to pass on:
hawk.portagebay.com
test-server.portagebay.com
All DNS'd via cloudflare, importantly only using them for DNS (no proxy).
So I really feel like there's an issue with this specific cloud provider. I just can't figure out what it is and prove it.
Well, we haven't seen one of these in quite a while.
There is a (very good) chance that your server hosting company is using a Palo Alto brand firewall.
That brand has an "Application" setting on the firewall for "ACME Protocol". They need to allow that. Some time back Palo Alto disabled ACME by default and we saw these problems often.
Even if not that brand they must have something similar in their firewall.
From my own AWS-based test server see the results below. You can probably easily reproduce this from other client systems. Using a "user-agent" string similar to Let's Encrypt fails with "reset by peer". The default curl string works as expected.
curl -i http://cedar.portagebay.com/.well-known/acme-challenge/Test404
HTTP/1.1 404 Not Found
Content-Type: text/html
Server: Microsoft-IIS/10.0
curl -i http://cedar.portagebay.com/.well-known/acme-challenge/Test404 -A "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
They are using Palo Alto, but have just ensured me they aren't blocking acme-protocol.
Make sure they're checking the inbound rules, from the Internet to the servers. It's kind of confusing, since the actual ACME protocol is spoken outbound from the server to the CA, but thing that Palo Alto labels as "ACME Protocol" is actually for incoming validation requests.
Ask them to run those two curl requests from outside the local network (so they pass through the firewall).
See if they can explain why the user-agent causes a "reset by peer"
