Terrible mistakes, tried to reinstall certbot and failed
My domain is: jiwon.me
The apache plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘There has been an error in parsing the file /etc/apache2/sites-available/certbot.log on line 2: Syntax error’,)
My web server is (include version): Server version: Apache/2.4.25 (Raspbian)
The operating system my web server runs on is (include version): Raspbian GNU/Linux 9 (stretch)
My hosting provider, if applicable, is: https://dnszi.com
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): ?
Ridiculously, I tried to delete certbot because it keeps saying error while trying to activate https.
It was a silly decision, but anyway I ran the command apt-get purge certbot, then reinstall the certbot.
Then first, I ran the command certbot --apache, and it gave me this message below.
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA.
And I searched and found another command,
certbot --authenticator standalone --installer apache -d jiwon.me --pre-hook "systemctl stop apache2" --post-hook "systemctl start apache2"
Then it gave me this message.
The error was: PluginError('There has been an error in parsing the file /etc/apache2/sites-available/certbot.log on line 2: Syntax error',)
I did a terrible mistake and I don’t know what to do at all.
Please, please help me.
Hi @2jiwon,
This shouldn't be a very big deal.
First, if you do sudo rm /etc/apache2/sites-available/certbot.log, you will get rid of the syntax error. This is a file created by Certbot but does not belong in that directory at all. If you want to move it instead, you could do
sudo mv -i /etc/apache2/sites-available/certbot.log ~
Then, you might want to know about the reason behind the error about the authenticator's challenge support.
(Using the standalone authenticator plugin will bypass this, but it might be more convenient to use the Apache authenticator plugin, the way you were trying to do, particularly since it doesn't require the hooks to start and stop the web server.)
Thank you! I’ll try this.
But for sure, what’s ‘webroot’ exactly?
Is it the same with the ‘document root’ of my site? like, /home/user1/public_html?
Can I run this command?
certbot --authenticator webroot --installer apache --webroot-path /home/<myusername>/public_html -d jiwon.me
Yes, as long as the site serves static files from under that document root.
Yes.
Thank you, @schoen. The problem resolved due to your help. I really appreciate you. :smile:
