Syntaxerror in certbot-auto
Not required as this is about a syntax error in certbot-auto
certbot-auto renew
/opt/eff.org/certbot/venv/bin/python: No module named pip.main; ‘pip’ is a package and cannot be directly executed
Irrelevant for this error
Ubuntu 12.04 LTS (Not upgradable for compatibility reasons to proprietary software that is not updated anymore)
not applicable
no
certbot 0.37.2
Details:
The problem is that since I think half a year certbot-auto has changed something, which is not supported at my system. Thus I always have to change the script after update. So everytime my certificate runs out, I have to change certbot-auto to make it work.
I’ve to replace the following lines, that it starts working again:
pip_version = StrictVersion(check_output([python, '-m', 'pip', '--version'])
by
pip_version = StrictVersion(check_output(['pip', '--version'])
and command = [python, '-m', 'pip', 'install', '--no-index', '--no-deps', '-U']
by
command = ['pip', 'install', '--no-index', '--no-deps', '-U']
Could you please provide some backward compatibility?
This will most likely be a problem because of the python version on your OS being very outdated. You could try to solve this by manually upgrading Python to the newest versions. A detailed explanation how to do this can be found on Stackoverflow: https://stackoverflow.com/questions/51646558/unable-to-install-python-packages-using-pip-in-ubuntu-linux-insecureplatformwar/54582701#54582701
