Hello,
I am looking for 2 weeks to install the certificate lets encrypt. I read some tutorials but it does not work.
Can anyone help me ? Please
The certificate lets encrypt is installed on my synology (DS618+ with DSM last update). Also, I see the renewal date on the certificate (12/06/2019). I had no error message.
I put this certificate by default and I deleted the old one (the self-signed synology certificate)
I use the synology domain name : xxx.synology.me
email : my email
Alternative name :
I checked: redirect the 5000 port to 5001
I disabled the firewall.
In my router (I use the freebox delta), I opened the ports then:
I redirected port 5000 to synology port 5000
I redirected port 5001 to port 5001 of synology
I redirected port 80 to port 80 of synology
I redirected port 443 to port 443 of synology
I restared my router.
But, i can’t to connect me to my server from the outside.
Inside, on my local network, i can to connect me with the domain name (xxx.synology.me:5001) but not with my ip:5001 and not with xxx.synology.me
Thank you for your help !
Hi @petityom
we need your real domain name to check that.
Checking a special port you can use my online tool ( https://check-your-website.server-daten.de/ ), that supports checks of non-standard ports like 5000 / 5001.
We have a list of tools
but most tools support only the standard ports 80 / 443.
Thank you !
Im sorry but im a beginner with the ssl certificate. Can you help me if i give you my real domain name ? I’m just a little bit afraid about to writing it here. Can you delete it after ? I tried to write you in pv but i dont find the possibility on this site.
Please read the standard template of the #help category:
My domain name is petityom.synology.me
Thank you very much
You have checked your domain yesterday - https://check-your-website.server-daten.de/?q=petityom.synology.me
There are only timeouts.
So your domain isn't visible, so Letsencrypt can't check your domain name.
PS: If you want to use http-01 validation, an open port 80 is required. You can use a redirect to port 443. But to check your domain, you can't use port 5000 or 5001.
You can install the certificate on that port. But to create a certificate, port 80 is required.
Or you use dns-01 validation. Then you don't need a running webserver.
So if i understand correctly, i have to change, in the dsm setting, the port 5000 in 80 and the port 5001 in 443 ?
Then open in the router the port 80 and 443 ?
Then renewal my certificate ?
Then, after that, i can to change, in the dsm setting, the port 80 in 5000 and the port 443 in 5001 ? And same for the router. And i have to let the 80 port open ?
You have already created some certificates:
https://crt.sh/?q=petityom.synology.me
The last - 2019-03-14.
And DSM has an own solution, so you don’t need an own client.
Perhaps you have to install the certificate, not only to create one.
Check the DSM documentation.
