I need help it's SSL to my synology DSM
It’s Synology DSM work space!!
I did DMZ to my DSM NAS
so i didn’t port forwarding my nas internal IP
my Xpenology 6.2.23… ds 3615xs
My domain is: jjongnas.duckdns.org
I ran this command: Do make let’s Encrypt
it’s synology DSM
Domain : jjongnas.duckdns.org
E mail Add : {my Email add}
sub Domain : jjongnas.duckdns.org
It produced this output: work failed you should re login
The operating syst
Hi @Jayz
checking your domain that looks ok - https://check-your-website.server-daten.de/?q=jjongnas.duckdns.org
Port 80 is open and answers, checking a random file in /.well-known/acme-challenge there is the expected result http status 404 - Not Found and a Synology page.
So if your Synology configuration is ok, the certificate creation should work.
--> First step: Check, if there is an update of your DSM.
You have some older certificates:
Let's Encrypt Authority X3 2019-09-22 2019-12-21 jjongnas.duckdns.org
1 entries
Let's Encrypt Authority X3 2019-07-19 2019-10-17 jjongnas.duckdns.org
1 entries
Let's Encrypt Authority X3 2019-05-15 2019-08-13 jjongnas.duckdns.org
1 entries
But why don't you use the certificate created 2019-09-22?
You use a self signed certificate.
CN=synology.com, O=Synology Inc., L=Taipei, C=TW
	30.11.2019
	17.08.2039
expires in 7197 days
Where is this certificate created 2019-09-22?
  1. Where is this certificate created 2019-09-22?
Because i re install and re bulid my nas … and my storage RAID is broken
So i can’t find it…
  1. Port 80 is open and answers, checking a random file in /.well-known/acme-challenge there is the expected result http status 404 - Not Found and a Synology page.
i set up DMZ
but do i must still do port forwarding 80 and 443 ??
Your port forwarding looks ok.
There
http://jjongnas.duckdns.org/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
is the expected result. Port 80 extern -> port 80 intern.
