My domain is: api.letsnoch.com
I ran this command: sudo certbot --nginx
It produced this output: permanently dropping privs did not work
My web server is (include version): nginx 1.14.1
The operating system my web server runs on is (include version): AlmaLinux release 8.7 (Stone Smilodon)
or certbot-auto --version
if you're using Certbot): N/A can't install certbot
rg305
December 31, 2022, 6:06am
2
Hi @Lance.Lewis , and welcome to the LE community forum
These two statements confuse me:
How did you (try to) install certbot
Osiris
December 31, 2022, 7:42am
3
Please provide more of the output, preferably the entire log file at /var/log/letsencrypt/letsencrypt.log
_az
December 31, 2022, 8:35am
4
It looks like this error comes verbatim from snapd
I tried installing Certbot via snapd on an AlmaLinux 8.7 x86_64 server and it worked OK for me. I'm not sure what would cause this.
I found a single report that looks to be the same issue here (about Certbot too, actually!) in this GitHub comment .
The reporter seems to suggest that trying to execute Certbot the first time via some magical combination of logged in user/sudo
worked for them.
Maybe you can try:
Login directly as root and then run Certbot without using sudo
, or
Login as a non-root user and run Certbot using sudo
, or
Login as a non-root user and sudo su -
and then don't use sudo
to run Certbot, or
and then do use sudo
to run Certbot.
Rudy,
You are correct the two statements don't make sense. I originally ran into problems with the yum install of certbot and created the ticket. I was, however, able to get around the certbot install issue then ran into the certbot --nginx
issue. I should have updated this on the ticket.
There is no log file in that dir or other.
Osiris
December 31, 2022, 10:33pm
7
Probably because the bug in snap makes that Certbot doesn't even get a chance to run.. And as the issue is with snap, it wouldn't matter anyway I'm afraid.
Thank you for the link and information. Based upon this I tried a few more attempts from a clean OS image. I was finally able to get past by using a standard user account with SUDO privileges.
system
Closed
February 2, 2023, 3:16pm
9
