I hope there is an easy fix for my issue. I'm a newb and attempted to manually enable TLS on my server via:
cd /etc/pki/tls/certs
sudo ./make-dummy-cert localhost.crt
and then opening /etc/httpd/conf.d/ssl.conf and commenting out
SSLCertificateKeyFile /etc/pki/tls/private/localhost.key
Then I created a CSR with a custom key I made via
sudo openssl req -new -key custom.key -out csr.pem
Realizing I could simply use Let's Encrypt and Certbot, I did that instead. It was successful. My domains are coming back secure on all browsers and computers EXCEPT for my single Chrome instance that I used when I tested the domain from the manual process. At that time it came back as not secure obviously since I didn't have it signed. It seems like Chrome is storing that version of the cert somewhere and didn't get replaced from my new ones that I created via Certbot.
Clearing Internet Cache, etc doesn't work. How can I clear the SSL state to get rid of it for this single browser?
From my searching, there apparently used to be an option in Chrome to clear SSL state, but it looks like in a recent update that option is gone. Others pleaing with google, but no answer:
https://support.google.com/chrome/thread/17653285?hl=en
Any ideas?
My domain is: www.digitalbovine.com
