I am having some issues with using the following setup:
My domain is hosted at Afraid.or where I have also created the subdomains.
Unifi USG is configured to update ddns at Afraid with IP and to use Synology DNS as primary DNS server.
Synology server is configured as DNS server with master zone configured as TLD and then resources corresponding to Afraid subdomains.
I also have reverse proxy configured in Synology Application portal to point to my other servers on the local network.
I have created lets encrypt certificates using synology web interface for TLD as well as sub domains.
I have a linux (18.04 LAMP) box with 2 of the FQDN (subdomains) being used to run 2 applications (Zoneminder &; Traccar)
I am however now stuck as when I try to go to the hostname traccar. domain.com I get ssl error stating that the issuer of the certificate is ubuntu. When I try and run certbot on the linux box I get:
CODE: SELECT ALL
Domain: traccar.[i]domain.com[/i]
Detail: Invalid response from
http://traccar.[i]domain.com[/i]/.well-known/acme-challenge/hBJoFjgJJ9iiWfNV1u_3qhbD_Fp1bCZexgjuL4f1K7E:
"<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<style>body{font-family:Arial,Helvetica,sans-serif;font-size:12px;text-alig"
I use port forwarding on my USG to open 80 and 443 and point these to my Synology NAS
Can someone point me in the right direction of how this should be configured?
