www.shining.lighting
sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/shining.lighting.conf
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
tls-sni-01 challenge for shining.lighting
Encountered vhost ambiguity but unable to ask for user guidance in non-interactive mode. Currently Certbot needs each vhost to be in its own conf file, and may need vhosts to be explicitly labelled with ServerName or ServerAlias directories.
Falling back to default vhost *:443…
Waiting for verification…
Attempting to renew cert from /etc/letsencrypt/renewal/shining.lighting.conf produced an unexpected error: Failed authorization procedure. shining.lighting (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: SERVFAIL looking up CAA for shining.lighting. Skipping.
/etc/letsencrypt/live/shining.lighting/fullchain.pem (failure)
Domain: shining.lighting
Type: connection
Detail: DNS problem: SERVFAIL looking up CAA for shining.lightingTo fix these errors, please make sure that your domain name was
raspberry pi debian jessie
apache 2
no
