StaticFiles Django not running with Certifield Let's Encrypt (Gunicorn + NGINX + Supervisor)
Hello,
have a python site with the django framework. On the server I use NGINX and Supervisor for Gunicorn.
NGINX was serving static files without the Let’s Encrypt certificate. But after I put it in, the static files are not served.
What should I do?
Can you provide more information?
What error message are you getting?
How is Nginx configured?
That’s the problem @mnordhoff . There is no error.
The problem is that you are not loading the still files with Certbot. But when the retreat, they are normally carried.
NGINX SETTINGS
#upstream mysite{ server 127.0.0.1:8000 fail_timeout=0; }
client_max_body_size 4G;
server_name mysite.net www.mysite.net;
access_log /var/log/nginx/mysite.access.log;
error_log /var/log/nginx/mysite.error.log;
location /static/ {
    alias /home/dev/sites/mysite/mysite/static/;
location /media/ {
    alias /home/dev/sites/mysite/mysite/media/;
    try_files $uri @proxy_to_app;
location @proxy_to_app {
    #proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    #proxy_set_header Host $http_host;
    #proxy_set_header X-Real-IP $remote_addr;
    proxy_pass http://127.0.0.1:8000;
ssl_certificate /etc/letsencrypt/live/mysite.net/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/mysite.net/privkey.pem; # managed by Certbot
if ($host = www.mysite.net) {
} # managed by Certbot
if ($host = mysite.net) {
listen 80;
location /static/ {
location /media/ {
