Nginx certfile does not exist
  • My domain is: api.avondale.io
  • I ran this command: supervisorctl restart all
  • It produced this output: myappname: ERROR (spawn error)
  • My web server is (include version): Nginx / Gunicorn via supervisord
  • The operating system my web server runs on is (include version): Debian 10
  • My hosting provider, if applicable, is: Linode
  • I can login to a root shell on my machine (yes or no, or I don't know): yes
  • I'm using a control panel to manage my site (no, or provide the name and version of the control panel): no
  • The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.31.0
Further Context
I'm running FastAPI using nginx/supervisor on a Debian server. All was working well, but when I upgraded my server, suddenly supervisor failed to start my app, throwing the following error (replaced domain with mydomainhere):
ValueError: certfile "/etc/letsencrypt/live/mydomainhere/fullchain.pem" does not exist
I have verified that the fullchain.pem file does in fact exist at the path described in the error, and has chmod 777.
Nginx Site Config (within /etc/nginx/sites-available):
upstream myproxy {
    server localhost:8000;
    listen 80;
    server_name api.avondale.io www.api.avondale.io;
    root /var/www/html;
        proxy_pass http://myproxy;
        proxy_set_header Host $host;
        proxy_redirect off;
    ssl_certificate /etc/letsencrypt/live/api.avondale.io/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/api.avondale.io/privkey.pem; # managed by Certbot
Supervisor Config (within /var/www/supervisor):
[program:myappname]
user=root
directory=/var/www
command=/var/www/app/bin/gunicorn -k uvicorn.workers.UvicornWorker app.main:app --bind 0.0.0.0:8000 --certfile=/etc/letsencrypt/live/mydomainhere/fullchain.pem --keyfile=/etc/letsencrypt/live/mydomainhere/privkey.pem
autostart=true
autorestart=true
stdout_logfile=/var/log/myappname/myappname.stdout.log
stdout_logfile_maxbytes=10mb
stdout_logfile_backups=5
stderr_logfile=/var/log/myappname/myappname.stderr.log
stderr_logfile_maxbytes=10mb
stderr_logfile_backups=5
environment = PYTHONUNBUFFERED=1
What am I missing?
The file in /live/ folder should be a symlink to a file in /archive/ folder.
Does that target file exist and do its permissions allow it to be read?
@MikeMcQ the .pem files in /archive/ all have the number 1 after them (fullchain1.pem). Will a simple mv do the trick to rename these to remove the 1's? Or will that mess with the symlink?
Edit: the files within /archive/ are 644 so I think we're good on the permissions front.
what does an ls -l for the live folder show
@MikeMcQ see below
total 4
lrwxrwxrwx 1 root root  39 Jun 19 21:58 cert.pem -> ../../archive/api.avondale.io/cert1.pem
lrwxrwxrwx 1 root root  40 Jun 19 21:58 chain.pem -> ../../archive/api.avondale.io/chain1.pem
lrwxrwxrwx 1 root root  44 Jun 19 21:58 fullchain.pem -> ../../archive/api.avondale.io/fullchain1.pem
lrwxrwxrwx 1 root root  42 Jun 19 21:58 privkey.pem -> ../../archive/api.avondale.io/privkey1.pem
-rw-r--r-- 1 root root 692 Jun 19 21:58 README
Looks like the links are all active still?
@MikeMcQ I also updated my original post with a few changes to the niginx .conf file that I made after making this post. Did not fix this problem, but making sure you and others see the change in case it impacts something...
In your supervisor config you have the path as mydomainhere
Is that actually the spelling? I had assumed it was redacted but ... :slight_smile:
Ha, yes, it's a placeholder. Anywhere you see mydomainhere it actually reads api.avondale.io
Well, that's all the easy stuff. Does your supervisor have access to the volume the certbot cert files are?
I mean, it's not magic. You can see the cert files. The symlinks seem fine. But your supervisor can't see them. The nginx error for missing cert files is different than that.
@MikeMcQ they're all on the same volume, so I can't imagine why supervisor wouldn't have access to them. This was all brought on by a server upgrade, though. I bumped up my Linode to the next tier, and when it finished booting, this error was present. Could something have gone awry during the upgrade that would have caused this?
It was an on-device upgrade... my IP and credentials remained the same, they just increased my provisioning.
The only other thing I can think of that would have caused the issue is that in a previous version of the config files, I was running supervisor using a non-root user. But, if anything, running as root would increase visibility into other directories/files, not decrease....
Is it worth trying to remove/reinstall some combination of nginx, supervisor, and certbot/certificates? I'm not sure what the best order/process would be for this, but that's the next thing I can think of, unless you've got another idea...
Is there a reason why you are only using one server block for both 80 and 443 ?
@rg305 pretty sure that's the way it was configured, but I could be way off base there. Would this be the fix?
upstream myproxy {
    listen 80;
    root /var/www/html;
        proxy_redirect off;
Do I need to re-list the server_name, root, and location/ lines in the second server block?
The 443 would also need:
server_name xxx;
root /somewhere;
And maybe the proxy stuff too
But no need for the location / block?
I can't say I know what you want it to do.
Most people redirect HTTP to HTTPS then handle things there.
If the final outcome is for it to be proxied, then I'd move that to 443
Got it, thanks @rg305! Here's what I have now in my nginx conf file:
upstream myproxy {
    listen 80;
    root /var/www/html;
    root /var/www/html;
        proxy_redirect off;
After running:
systemctl restart nginx
supervisorctl reread
...I'm still getting the same error I had before...
This doesn't error?:
@rg305 nope, nginx is running fine. Here's the output of systemctl status nginx:
● nginx.service - A high performance web server and a reverse proxy server
   Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
   Active: active (running) since Mon 2022-06-20 01:39:28 UTC; 19s ago
     Docs: man:nginx(8)
  Process: 5304 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
  Process: 5305 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
 Main PID: 5307 (nginx)
    Tasks: 2 (limit: 2359)
   Memory: 2.8M
   CGroup: /system.slice/nginx.service
           ├─5307 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
           └─5308 nginx: worker process
Jun 20 01:39:28 localhost systemd[1]: Starting A high performance web server and a reverse proxy server...
Jun 20 01:39:28 localhost systemd[1]: nginx.service: Failed to parse PID from file /run/nginx.pid: Invalid argument
Jun 20 01:39:28 localhost systemd[1]: Started A high performance web server and a reverse proxy server.
root@localhost:/etc/supervisor#
The issue appears to be entirely with supervisord which fails to start up.
That isn't wonderful though...
But I see it starts successfully.
What is the exact error? - please don't change anything within it.
