AIRMAXM
November 23, 2019, 7:58pm
#1
My domain is: airmaxbilling.com
We are using UNMS ubiquiti
and we get this error for the last 2 days
Last refresh of SSL certificate had failed.
Timestamp: Today at 1:27 pm
Error: Challenge failed for domain airmaxbilling.com
Failed to generate or update Let’s Encrypt certificate.
Hi @AIRMAXM
I have no idea how that client works.
But checking your domain your port 80 is closed - https://check-your-website.server-daten.de/?q=airmaxbilling.com
Same with http + /.well-known/acme-challenge/random-filename.
If that tool uses http validation, an open and working port 80 is required.
Perhaps there is a firewall or something else that blocks.
PS: There are two older Letsencrypt certificates:
Last is from 2019-11-01. Where is that certificate? Why isn't it possible to use that?
rg305
November 23, 2019, 10:12pm
#3
AIRMAXM:
UNMS ubiquiti
Seems to run on:
Supported Distros (LXC virtualized Distros aren’t officially supported please use KVM):
WHICH ONE ARE YOU RUNNNG?
WHICH ACME CLIENT ARE YOU USING?
AIRMAXM
November 23, 2019, 10:30pm
#4
thank you so much that did the trick, port 80 was closed in our new server
Now you have a certificate.
But only with one domain name.
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
Let’s Encrypt Authority X3
2019-11-23
2020-02-21
airmaxbilling.com - 1 entries
duplicate nr. 3
2019-11-23
2020-02-21
duplicate nr. 2
2019-11-23
2020-02-21
duplicate nr. 1
2019-11-01
2020-01-30
airmaxbilling.com , www.airmaxbilling.com - 2 entries
So your www version isn’t secure. Create one certificate with both domain names and use that.
system
Closed
December 23, 2019, 10:56pm
#6
