SSL/TLS connection failed
I have downloaded certificate file 5102836967.crt from url
#mv 5102836967.crt /etc/ssl/certs/ca.crt
#vi /etc/apache2/sites-available/default-ssl.conf
Change the CA into
SSLCACertificatePath /etc/ssl/certs/
SSLCACertificateFile /etc/ssl/certs/ca.crt
Restart apache2:
#service apache2 restart
And it doesn't work.
$ curl -Iki https://www.mydomain.top:8443/list_score.php
curl: (35) LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to www.mydomain.top:8443
Unexpected.
The leaf cert should not be used this way.
I already spoke about these two entries:
OpenSSL 1.0.1f went out of support in December 2016; but it did support TSv1.2.
You should upgrade it if possible and
Please show file:
/etc/apache2/mods-enabled/ssl.conf
And most importantly...
Is your site behind the Great Firewall of China?
cat /etc/apache2/mods-enabled/ssl.conf
<IfModule mod_ssl.c>
        SSLRandomSeed startup builtin
        SSLRandomSeed startup file:/dev/urandom 512
        SSLRandomSeed connect builtin
        SSLRandomSeed connect file:/dev/urandom 512
        AddType application/x-x509-ca-cert .crt
        AddType application/x-pkcs7-crl .crl
        SSLPassPhraseDialog exec:/usr/share/apache2/ask-for-passphrase
        SSLSessionCache         shmcb:${APACHE_RUN_DIR}/ssl_scache(512000)
        SSLSessionCacheTimeout  300
        SSLCipherSuite HIGH:MEDIUM:!aNULL:!MD5
        SSLProtocol all
</IfModule>
And my site is behind the Great Firewall of China.
Then you may need to speak with whomever about https access to your site through that firewall.
:cry:
It's a problem.
So it seems.
Can you use a host on the other side of that firewall?
[and thanks to @JimPas for pointing out this possible firewall problem]
No other host.
:slight_smile:
Then I don't think we can fix this problem for you.
So sad.Thanks all!
A post was split to a new topic: My site is continuously unreachable
