Secure Connection Failed - SSL_ERROR_RX_RECORD_TOO_LONG
I recently used a Digital Ocean one click installer to create a Ubuntu 18.04 installation which included Certbot.
After running certbot and creating the certificate and restarting Apache:
/etc/letsencrypt/live/bin-depot.co.uk-0001/fullchain.pem
/etc/letsencrypt/live/bin-depot.co.uk-0001/privkey.pem
Your cert will expire on 2019-02-09. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew all of your certificates, run
“certbot renew”
… I got not response from my site when trying to connect via HTTPS.
I then updated /etc/apache2/ports.conf to include 443:
Listen 80
Listen 443
Then in /etc/apache2/sites-available I updated ‘default-ssl.conf’ to:
<IfModule mod_ssl.c>
	<VirtualHost _default_:443>
		DocumentRoot /var/www/html
		#   SSL Engine Switch:
		#   Enable/Disable SSL for this virtual host.
		SSLEngine on
		SSLCertificateFile /etc/letsencrypt/live/bin-depot.co.uk-0001/fullchain.pem
		SSLCertificateKeyFile /etc/letsencrypt/live/bin-depot.co.uk-0001/privkey.pem
		ServerName bin-depot.co.uk
		SSLVerifyClient require
		SSLVerifyDepth  10
		#   SSL Engine Options:
		SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
		<FilesMatch "\.(cgi|shtml|phtml|php)$">
				SSLOptions +StdEnvVars
		</FilesMatch>
		<Directory /usr/lib/cgi-bin>
		</Directory>
		#   SSL Protocol Adjustments:
		 BrowserMatch "MSIE [2-6]" \
				nokeepalive ssl-unclean-shutdown \
				downgrade-1.0 force-response-1.0
	</VirtualHost>
</IfModule>
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
This is what my 000-default.conf looks like:
<VirtualHost *:80>
        <Directory /var/www/html/>
            Options FollowSymLinks
            AllowOverride All
            Require all granted
        </Directory>
</VirtualHost>
Firefox is reporting the error “Secure Connection Failed - SSL_ERROR_RX_RECORD_TOO_LONG”
I’m fairly sure I’m making some mistakes with the above. Can anyone point me in the right direction? Domain is https://bin-depot.co.uk.
It seems that you did not specify the SSL protocol and cipher to use in the virtual host… Did you specify those else where?
Thank you
Hi Steve, how and where do I place this information? Other than the above I haven’t edited other files.
Just to add to this, adding the following code:
<VirtualHost *:80>
        ServerAdmin dan@***.com
            AllowOverride All
            Require all granted
        </Directory>
</VirtualHost>
#get encrypted requests:
<VirtualHost *:443>
    ServerAlias www.bin-depot.co.uk
    # include tls key and certificates:
    SSLEngine On
    SSLCertificateFile /etc/letsencrypt/live/bin-depot.co.uk/fullchain.pem
    SSLCertificateKeyFile /etc/letsencrypt/live/bin-depot.co.uk/privkey.pem
    #directory config:
        AllowOverride All
        Require all granted
    </Directory>
    #logging:
</VirtualHost>
…to ‘000-default.conf’ breaks apache with the error:
Job for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xe" for details.
Hi @dan382,
Two things.
1.- Did you enable ssl module?.
sudo a2enmod ssl
sudo systemctl restart apache2
2.- In your conf you are using this path to define the certificate and privkey /etc/letsencrypt/live/bin-depot.co.uk/... but in the output of your certbot command the path for your cert is /etc/letsencrypt/live/bin-depot.co.uk-0001/... so which one is the right one?.
You can check the certificates issued using this command:
sudo certbot certificates
Cheers,
sahsanu
Please also show:
ls -l /etc/apche2/sites-enabled/
grep -Eri 'servername|serveralias|80|443' /etc/apache/sites-enabled/
Ran: ls -l /etc/apache2/sites-enabled/ and got the output:
total 0
lrwxrwxrwx 1 www-data www-data 35 Oct 3 14:31 000-default.conf -&gt; ../sites-available/000-default.conf
However, grep -Eri ‘servername|serveralias|80|443’ /etc/apache/sites-enabled/ created the following error:
grep: /etc/apache/sites-enabled/: No such file or directory
Think I’ve run certbot more than once. Both appear to be correct:
Found the following certs:
  Certificate Name: bin-depot.co.uk
    Domains: bin-depot.co.uk www.bin-depot.co.uk
    Expiry Date: 2019-02-08 09:34:39+00:00 (VALID: 87 days)
    Certificate Path: /etc/letsencrypt/live/bin-depot.co.uk/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/bin-depot.co.uk/privkey.pem
  Certificate Name: bin-depot.co.uk-0001
    Expiry Date: 2019-02-09 22:16:49+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/bin-depot.co.uk-0001/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/bin-depot.co.uk-0001/privkey.pem
I’ve corrected both to be the latest ‘bin-depot.co.uk-0001’ versions.
Not sure which step has helped, but things looked to have clicked. I can now connect to the site over HTTPS. Thanks for the feedback. It might have simply been the command:
sudo a2enmod ssl
Hi @dan382,
Yes, seems activating ssl module solved the problem :wink:
Just one thing, the certificate with 0001 suffix only covers your main domain, the other one covers the main domain and www subdomain so I would use this.
Modify again your apache conf to point the SSL directives to path /etc/letsencrypt/live/bin-depot.co.uk/ instead of etc/letsencrypt/live/bin-depot.co.uk-0001/, restart apache, check if you can access to your site y and then remove the certificate covered by cert name bin-depot.co.uk-0001.
sudo certbot delete
And select the number of the certificate with name bin-depot.co.uk-0001
or if your certbot version is a recent version you can use directly this command:
sudo certbot delete --cert-name bin-depot.co.uk-0001
Cheers,
sahsanu
Thanks Sahsanu, I’ll make sure that gets done next.
