SSL not working correctly on AWS EC2
Hello,
I can really use some help! First of all, thank you for creating this amazing product! The internet needs people like you! I just got the SSL installed and it looks like its almost working:) For one the SSL does not appear as secure when using chrome. https://i.imgur.com/MC6otT6.png and for some reason, it looks like all the CSS and Js is not loading. When I browse using regular http://caralbert.com it works fine. My ssl.config has:
SSLCertificateFile /etc/letsencrypt/live/caralbert.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/caralbert.com/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/caralbert.com/chain.pem
Not sure what am I missing :frowning:
https://caralbert.com
sudo ./certbot-auto --debug -v --server https://acme-v01.api.letsencrypt.org/directory certonly -d caralbert.com
Congratulations! Your certificate and chain have been saved at:
Apache/2.4.33 (Amazon)
Linux 14.62-65.117.amzn1.x86_64
AWS
YES
NO
Certonly will not install the cert.
It will only get the cert.
Look at:
sudo ./certbot-auto certificates
and you should see the cert.
Thank you for replying so quickly. Here’s the output I am getting:
Found the following certs:
Certificate Name: caralbert.com
Domains: caralbert.com
Expiry Date: 2018-11-20 05:53:52+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/caralbert.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/caralbert.com/privkey.pem
Hi @nikitantra
your certificate is good and is already installed. So this part is done.
But there https://caralbert.com/ are mixed content warnings. So the page loads content via http, not https.
Use FireFox or Chrome, Ctrl + Shift + I, then open the console. There you see a lot of mixed content warnings:
http :// caralbert . com / media/main-slider/1.jpg
Change them to https.
Yep, looks like its all working now! thank you very much!
