SSL Not Generating
Hello i am unable to Generate SSL for following domain
Heres the output i get after running ssl generation command
Please Help me urgently whats the issue is this dns problem required
Check that your website's webroot in nginx is indeed /usr/share/nginx/html otherwise certbot will be writing files but requests to https://walletlytest.xyz/.well-known/acme-challenge won't return the correct information.
I note that your website currently has a cert that resolves to aaagroup.xyz which implies you have multiple sites on this server, which also implies that /usr/share/nginx/html is not the actual webroot for this site (is it a subfolder of that?)
when i run command this is error firewall issue is this problem due to local network
the multiple domain is serving same site whitelabeling
Does anyone know about whats going wrong in this command?
@Naveed10 Cross posting isn't going to help. You'll eventually get help on your original thread: SSL Not Generating
@Naveed10 welcome to the LE community forum :slight_smile:
The "python/urllib" errors seem to be caused when certbot has been installed via pip.
In any case, I would recommend that you uninstall certbot (don't delete anything manually).
Then reinstall it from APT or SNAPS.
I reinstall snapd but same error
@Naveed10 You seem to have a server config problem or using the wrong -w location in your Certbot command. This was pointed out by @webprofusion in post #2 in this thread.
The path used for -w should match the root folder in the nginx server definition for walletlytest.xyz
If you still can't get it to work, please run sudo nginx -T and post the results. Use three backticks (```) before and after the output to have it nicely formatted. Or, save the output to a file and upload it.
That is a different error.
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
        worker_connections 768;
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        tcp_nodelay on;
        keepalive_timeout 65;
        types_hash_max_size 2048;
        # server_tokens off;
        # SSL Settings
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
        ssl_prefer_server_ciphers on;
        # Logging Settings
        # Gzip Settings
        gzip on;
        # gzip_vary on;
        # gzip_proxied any;
        # gzip_comp_level 6;
        # gzip_buffers 16 8k;
        # gzip_http_version 1.1;
        # Virtual Host Configs
#mail {
#       # See sample authentication script at:
#       # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#       # auth_http localhost/auth.php;
#       # pop3_capabilities "TOP" "USER";
#       # imap_capabilities "IMAP4rev1" "UIDPLUS";
#       server {
#               listen     localhost:110;
#               protocol   pop3;
#               proxy      on;
#       server {
#               listen     localhost:143;
#               protocol   imap;
#               proxy      on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/conf.d/aaagroup.xyz.conf:
   listen         80;
   listen         [::]:80;
   server_name    www.aaagroup.xyz aaagroup.xyz;
   root           /usr/share/nginx/html;
   return 301     https://$host$request_uri;
server{
   listen         443 ssl;
   listen         [::]:443 ssl;
   root /home/ubuntu/walletly2-live-react-frontend-v1/build;
      try_files $uri /index.html;
   ssl_certificate /etc/letsencrypt/live/aaagroup.xyz/fullchain.pem;
   ssl_certificate_key /etc/letsencrypt/live/aaagroup.xyz/privkey.pem;
   location /api/ {
      proxy_pass http://0.0.0.0:8080/;
      proxy_http_version 1.1;
      proxy_set_header Connection 'upgrade';
      proxy_set_header Host $host;
      proxy_cache_bypass $http_upgrade;
   location ~ /.well-known {
      allow all;
# configuration file /etc/nginx/conf.d/business.futuremoneyclub.com.au.conf:
    if ($host = business.futuremoneyclub.com.au) {
    } # managed by Certbot
   listen         80;
   listen         [::]:80;
   server_name    business.futuremoneyclub.com.au;
server{
   listen         443 ssl;
   location /api/ {
      allow all;
    ssl_certificate /etc/letsencrypt/live/business.futuremoneyclub.com.au/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/business.futuremoneyclub.com.au/privkey.pem; # managed by Certbot
# configuration file /etc/nginx/conf.d/v2-live-walletly.conf:
       server_name api.walletly.ai;
       location /api/ {
    ssl_certificate /etc/letsencrypt/live/api.walletly.ai/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/api.walletly.ai/privkey.pem; # managed by Certbot
    if ($host = api.walletly.ai) {
    listen 80;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers off;
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384";
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
        listen 80 default_server;
        # SSL configuration
        root /var/www/html;
        server_name _;
                try_files $uri $uri/ =404;
        #location ~ \.php$ {
        #       include snippets/fastcgi-php.conf;
        #       # With php-fpm (or other unix sockets):
        #       fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
        #       # With php-cgi (or other tcp sockets):
        #       fastcgi_pass 127.0.0.1:9000;
        # concurs with nginx's one
        #location ~ /\.ht {
        #       deny all;
#server {
#       listen 80;
#       listen [::]:80;
#       server_name example.com;
#       root /var/www/example.com;
#       index index.html;
#       location / {
#               try_files $uri $uri/ =404;
I am first generating the ssl and then the conf file for that ssl is being made by script of code
@Naveed10 Thanks. I will look at it. Please change the backtick marks on top and bottom to just 3 backticks: ```
I should have been clearer about that. I have the info ok - changing will help others
thanks i urgently need the answer
the command i am running is following
sudo certbot certonly -a webroot --webroot-path=/usr/share/nginx/html -n -d ${domain} -d www.${domain} --expand
@Naveed10 Your certbot certonly command for ... -d walletlytest.xyz ... is failing because you do not have a server definition by that name in your nginx conf. In that case, nginx will use the default server which in your case is the first server defined for www.aaagroup.xyz aaagroup.xyz;
You need to add a server definition for walletlytest.xyz in a similar manner as you have all your other servers defined.
i am trying to generate ssl first then i have default.conf file in which current domain is replaced by placeholder and we move that conf file to conf.d folder
Hmmm. I think I understand. Is the nginx conf you showed the active conf when running the certbot command? Or do you run nginx with just the default conf template for that?
Also, this will not change anything but I think you should move your:
allow all;
from the server definitions for 443 and put it in the port 80 section. The challenge requests from Lets Encrypt will come to port 80 so you can process it more quickly there. You currently redirect all port 80 (http) requests to 443 (https) which is slower and adds complication.
You need a functional HTTP site before you can secure it (via HTTP authentication).
Add something like:
  server_name walletlytest.xyz www.walletlytest.xyz;
  root /var/www/html;
  location ~ /.well-known/acme-challenge {
    allow all;
@rg305 Rudy, I think they are trying to automate the creation of a long series of server defs. They seem to use a different conf when actually running the certbot request. I say this because the posted conf redirects all http traffic to https. But, the errors they posted earlier show a request to just the http well-known endpoint (which was not redirected).
Also, the default server in the posted conf has a root folder different than used in their -w webroot path. So, I think there is a different conf used.
So, I think their process goes like this:
  1. Start nginx with just a single default server for port 80
  2. Run a series of certbot commands to generate certs. Create a 'master' server def file with names from each successful cert. The default nginx server will process any server name challenge request due to nginx SNI name selection. The SNI name wont match anything so just falls into default server.
  3. Stop nginx and restart it using the 'master' conf just created
I could be wrong, but that's how I interpret the explanation. A couple things do not fit that idea well such as they have a location statement for /.well-known in their port 443 listener in the 'master' which would not be needed. Unless they plan to renew via the master conf with a different process than this initial setup.
I would be inclined to do such a thing differently. This method, if that's what they are doing, is trickier to debug and not very intuitive.
