Ssl installation on subdomain
Hello i want install letsencrypt ssl on subdomain qa-int.juvlon.in already install on same server on another subdomain, please let me know how can i install ssl on another subdomain.
OS - Ubuntu 14
Webserver - nginx
For some reason you’ve removed the questionnaire which was presented to you when you started this thread in the Help category. Or for some reason it was never presented, we may never know. However, without a properly filled in questionnaire, we can’t help you, as there is much required information missing. Crystal balls don’t actually exist so we need you to tell us:
My domain is:qa-int.juvlon.in
I ran this command:no
It produced this output: no
My web server is (include version): nginx version: nginx/1.9.10
The operating system my web server runs on is (include version): Ubuntu 14.04.3 LTS \n \l
My hosting provider, if applicable, is: AWS
I can login to a root shell on my machine (yes or no, or I don’t know): YES
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): NO
if your webserver is configured to serve the subdomain, you just need to open a shell and launch certbot. It will ask what domains/subdomains you want a certificate for and do everything needed. Just be sure your firewall isn’t in the way.
root@qa-ui:~/letsencrypt# certbot.
certbot.: command not found
on same server another ssl activate on another domain
Hello
i have recieved below error at the time of installing
Problem in /etc/nginx/sites-enabled/qa-int.juvlon.in: tried to insert directive “[‘ssl_prefer_server_ciphers’, ‘off’]” but found conflicting “[‘ssl_prefer_server_ciphers’, ‘on’]”.
installation done thanks
Sounds like everything is good? You don’t need any further assistance?
