I am facing issue on my subdomain I have succesfully installed ssl from my cpanel on my main domian but it seems its not working with subdomain
eshop.luxeautospa.pk
I installed through cpanel directly
activated on main domain but not on subdomain
linux
tso host
I don’t know
yes I am using cpanel
Hi @dublewW
the eshop has the ip 95.142.152.194.
The luxeautospa.pk has 185.119.173.100
Two different ip addresses, same cPanel? If your cPanel runs on the 185.119.173.100, you can't create there a certificate with the eshop subdomain.
Hey thanks for pointing out, No its the same cpanel shall I change ip for eshop by editing the dns? or do you have any other suggestion?
How should that work if your shop runs under that other ip?
Please read some required basics:
Normally, a (new) ACME client must run on your shop - ip - machine. That has nothing to do with your main domain if the ip is different.
