Dear friends, Hope you doing awesome!
I am trying to activate my SSL Certificate on my GCP compute instance where I am running my WordPress website with nginx/1.19.1 and Ubuntu 18.04 LEMP setup, I am trying to activate the SSL using below procedure and it went well, however, the website didn’t open even in HTTP mode after complete the procedure as per below blog
[https://www.cloudbooklet.com/install-web-apps-with-ssl-certificate-on-google-cloud-platform/]
I am also uploading my Nginx config file for your kind help here.
Thanks for your help
There’s not that much information for the link you provided. (and i didn’t see your nginx file)
Please find the required details here
1.My domain is: ravindrabhargava.com
2.I ran this command: meetravi007@ravi-wordpress-cloud-blog:/etc/nginx/sites-available$ sudo nginx -t
3.It produced this output:
nginx: [warn] conflicting server name “www.ravindrabhargava.com” on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name “ravindrabhargava.com” on 0.0.0.0:80, ignored
4.My web server is (include version): NGINX
meetravi007@ravi-wordpress-cloud-blog:~$ nginx -v
nginx version: nginx/1.19.1
5.The operating system my web server runs on is (include version): Ubuntu 18.04
meetravi007@ravi-wordpress-cloud-blog:~$ uname -a
Linux ravi-wordpress-cloud-blog 5.3.0-1032-gcp #34~18.04.1-Ubuntu SMP Tue Jul 14 22:07:36 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
6.My hosting provider, if applicable, is: I am hosting by my own , using LEMP stack installed on VM running on Google cloud compute engine.
7.I can login to a root shell on my machine (yes or no, or I don’t know): Yes , using “sudo su -”
8.I’m using a control panel to manage my site (no, or provide the name and version of the control panel): I am using the command line on the server
- The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0 meetravi007@ravi-wordpress-cloud-blog:~ certbot --version
certbot 0.31.0
You may download my NGINX config file here since I am not able to upload it here
[https://drive.google.com/file/d/1Nn6cp39cuz2vqgUzj54amkm_FQLY9qOX/view?usp=sharing]
I think the reason your site can’t be opened is because your port 443 is not open or being filtered by a firewall.
First, check your GCP’s platform firewall: https://docs.bitnami.com/google/faq/administration/use-firewall/
Then, check your compute instance firewall (check iptables, firewalld or ufw)
P.S. I merged your configuration into one virtual host file: https://pastebin.com/5LVMg09i.
You might also have a duplicate virtual host configuration for your HTTP virtual host, you can run sudo nginx -T for a complete list of virtual host files currently in use and remove the duplicate for both hostnames.
Thank you
Thanks for your guidance, I noticed that my ufw was not having HTTPs so I activated the Nginx https on my webserver
meetravi007@ravi-wordpress-cloud-blog:/etc/nginx$ sudo ufw status
Status: active
To Action From
Nginx HTTP ALLOW Anywhere
ALLOW Anywhere
Nginx HTTPS ALLOW Anywhere
Nginx HTTP (v6) ALLOW Anywhere (v6)
ALLOW Anywhere (v6)
Nginx HTTPS (v6) ALLOW Anywhere (v6)
After that I manage to redirect my all request to my https domain name, however, after using your config file I am still not able to activate my SSL yet, seems something still missing by me.
when I test it its perfectly fine now
meetravi007@ravi-wordpress-cloud-blog:/etc/nginx$ sudo nginx -t
meetravi007@ravi-WordPress-cloud-blog:/etc/nginx$
However my ssl still not working, when i refresh the browser page its shows a secure connection for a millisecond then again insecure.
Don’t know what else I should correct now
I am sending my nginx.cong, /conf.d/ravindrabhargava.com.conf and /site-available/ ravindrabhargava.com.conf for your kind review, please let me know how I can adjust these files now to activate SSL.
[https://drive.google.com/drive/folders/1wn4HggXJYI-k6lbuSHyC6MuiHM0RQPdy?usp=sharing]
Thank you very much for your help
You’ll need to adjust your WordPress settings since it’s mixed content issue. https://www.whynopadlock.com/results/56fbb65d-438e-4ad3-8083-22431f38bd2a
First, make sure to change your WordPress URL to https version (on your backend), then if you are using any content builder, you might need to change individual pictures as well.
I think on mysql db its already updated as https but still I am not able to get secure connection
Kindly guide me
mysql> SELECT * FROM wp_options WHERE option_name = ‘home’;
| option_id | option_name | option_value | autoload |
| 2 | home | https://ravindrabhargava.com | yes |
1 row in set (0.00 sec)
mysql>
mysql>
mysql>
mysql> SELECT * FROM wp_options WHERE option_name = ‘siteurl’;
| 1 | siteurl | https://ravindrabhargava.com | yes |
mysql>
