Hello Hello
I made a wrong move to delete the content from the Live folder in letsencrypt and now I can not rebuild my domain I try and receive this error
requests.exceptions.SSLError: HTTPSConnectionPool (host = 'acme-v02.api.letsencrypt.org', port = 443): Max retries exceeded with url: / directory (Caused by SSLError (SSLError ("bad handshake: Error ([) 'SSL routines', 'tls_process_server_certificate', 'certificate verify failed')]) ")))
Please see the logfiles in / var / log / letsencrypt for more details.
can somebody help me?
Show me the output of
curl -vvv https://acme-v02.api.letsencrypt.org/directory
- Trying 172.65.32.248:443...
- TCP_NODELAY set
- Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0)
- ALPN, offering h2
- ALPN, offering http/1.1
- successfully set certificate verify locations:
- CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs
- TLSv1.3 (OUT), TLS handshake, Client hello (1):
- TLSv1.3 (IN), TLS handshake, Server hello (2):
- TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
- TLSv1.3 (IN), TLS handshake, Certificate (11):
- TLSv1.3 (OUT), TLS alert, bad certificate (554):
- SSL certificate problem: certificate is not yet valid
- Closing connection 0
curl: (60) SSL certificate problem: certificate is not yet valid
More details here: curl - SSL CA Certificates
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
Can you check the clock on your system?
root@fileserver:~# date
Sat 16 Apr 2022 05:56:35 PM UTC
yes its worng
yes all works perfect now!!!! thnx community!!!
