Ssl generated and installed but is not working
My domain is: bruce lorio
I ran this command:letsencrypt.exe and it worked fine i even trouble shoot the reason why the acme was not able to reach the folder and could not load a file without an extension , but got that fix
My web server is (include version): windows server 2012 r2
My hosting provider, if applicable, is: i am hosting it my self.
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no directly using remote desktop connectoin
Hi @bc28001,
That's a human name, not an Internet domain name. Could you tell us what domain name you've registered and issued a Let's Encrypt certificate for?
If you're using IIS, you'll need to create a binding using the certificate after you issue it—I'm not certain, but I don't think that letsencrypt.exe does this for you automatically.
oh im sorry about that. the domain of the site is twnindustries.com
about the bindings for iis do you have some instructions that would help me please. ?
i did some off the binding my self and i think i understand that part but i dont see it working i guess im missing something on the ssl side hope you can help please.
this is what im getting no matter what i do no changes
sorry im trying to give you as much information as possible . sir
http://twnindustries.com/.well-known/acme-challenge/configcheck
Hi @bc28001
you have created a lot of certificates ( https://check-your-website.server-daten.de/?q=twnindustries.com#ct-logs ):
Let's Encrypt Authority X3 2019-07-08 2019-10-06 twnindustries.com - 1 entries duplicate nr. 2
Let's Encrypt Authority X3 2019-07-08 2019-10-06 twnindustries.com, www.twnindustries.com - 2 entries duplicate nr. 5 next Letsencrypt certificate: 2019-07-12 13:24:26
Let's Encrypt Authority X3 2019-07-08 2019-10-06 twnindustries.com, www.twnindustries.com - 2 entries duplicate nr. 4
Let's Encrypt Authority X3 2019-07-05 2019-10-03 twnindustries.com, www.twnindustries.com - 2 entries duplicate nr. 3
Let's Encrypt Authority X3 2019-07-05 2019-10-03 twnindustries.com, www.twnindustries.com - 2 entries duplicate nr. 2
Let's Encrypt Authority X3 2019-07-05 2019-10-03 twnindustries.com, www.twnindustries.com - 2 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-07-05 2019-10-03 twnindustries.com - 1 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-07-03 2019-10-01 www.twnindustries.com - 1 entries duplicate nr. 2
Let's Encrypt Authority X3 2019-07-02 2019-09-30 www.twnindustries.com - 1 entries duplicate nr. 1
So that part works.
But your https doesn't answer.
173.162.67.50 200 0.500 H
http://www.twnindustries.com/
173.162.67.50 200 0.473 H
https://twnindustries.com/
173.162.67.50 -14 10.030 T
Timeout - The operation has timed out
https://www.twnindustries.com/
173.162.67.50 -14 10.017 T
Please share a screenshot of your binding configuration.
154%20-%20Remote%20Desktop%20Connection
im sorry for adding too many request is that i though i was doing something wrong and i try many times as you can see sorry
154%20-%20Remote%20Desktop%20Connection i try also with and without the ip
Do you have more then one domain on that server? Or is it a shared hosting?
If yes, “Server Name Indication” must be checked.
i have only one server im hosting it my self. in inhouse server and is only one site nothing else.
is not share hosting
if you have a secure connection i can give you access with team-viewer so you can see for your self the settings.
154%20-%20Remote%20Desktop%20Connection i also try to use this software thinking that i was doing something wrong . and still can not get it right way. . im stuck and need you assistance sir. sorry
Please check “Server Name Indication” and save that.
154%20-%20Remote%20Desktop%20Connection done please check
154%20-%20Remote%20Desktop%20Connection i try with the IP assigned too . to see if that make a difference but nothing. do you want to try team viewer?
The tool is online, so please use it.
But if your http works, your https not:
  • Works your https internally?
  • Looks like a blocking firewall or a wrong router configuration. So port 443 extern isn't forwarded to port 443 intern.
That
twnindustries.com A 173.162.67.50 Fort Lauderdale/Florida/United States (US) - Comcast Cable Communications Hostname: 173-162-67-50-miami.hfc.comcastbusiness.net yes 2 0
AAAA yes
www.twnindustries.com C twnindustries.com yes 1 0
looks like a home server.
yes i have my own server. so you think i should be looking to the dsn configuration at godaddys?
