SSL for WordPress using LightSail
Hello everyone,
I’m new using Amazon LightSail. I’m following this link: https://lightsail.aws.amazon.com/ls/docs/en_us/articles/amazon-lightsail-using-lets-encrypt-certificates-with-wordpress
I’m trying to configure the SSL certificate for WordPress, I’m on the Step 5 on the Guide. When i use MX Toolbox to verify the DNS Record until now it showing “DNS not found”. It’s been a day since I added it to the panel, but it hasn’t propagated yet.
what’s the problem? I’ve tried to follow the guide several times, I don’t understand what I’m doing wrong.
Thanks for help.
Note: At this moment, the site is hosted on another server and the domain is registered with another company. We just want to migrate the site to AWS. We already did, we are just configuring SSL.
Check my image, please:
www.vinicom.pt
sudo certbot -d $DOMAIN -d $WILDCARD --manual --preferred-challenges dns certonly
Display 2 DNS Zone TXT Records. I added on the Network panel .
Linux Server
I think is Linux OS.
Amazon LightSail
Yes.
LightSail’s Control Panel
I have the latest version. I ran the commands to update the system.
Don't use MX toolbox, it only checks MX records. You need to check A and TXT records.
also: you are not using amazon's nameservers, so whatever you put there is not considered.
% dig vinicom.pt ns
; <<>> DiG 9.16.1-Ubuntu <<>> vinicom.pt ns
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 46363
;; flags: qr rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 65494
;; QUESTION SECTION:
;vinicom.pt.			IN	NS
;; ANSWER SECTION:
vinicom.pt.		3599	IN	NS	ns2.ptempresas.pt.
vinicom.pt.		3599	IN	NS	ns1.ptempresas.pt.
vinicom.pt.		3599	IN	NS	ns10.ptempresas.pt.
;; Query time: 88 msec
;; SERVER: 127.0.0.53#53(127.0.0.53)
;; WHEN: mar apr 14 12:16:38 CEST 2020
;; MSG SIZE  rcvd: 105
Hello 9peppe,
Our domain is registered on the ptempresas.pt.
Do i need to add the amazon nameservers at this company?
Thanks for reply.
Hi @SergioCosta86
there is a check of your domain, ~~30 minutes old - https://check-your-website.server-daten.de/?q=vinicom.pt
These
vinicom.pt
	•  ns1.ptempresas.pt
	62.28.40.139
Lisbon/Portugal (PT) - PT Prime	•
	•  ns10.ptempresas.pt
	185.17.231.126
	•  ns2.ptempresas.pt
	62.28.40.141
are your name servers, nothing else.
If you use dns validation + manual, your TXT entry must be visible. But there
is nothing visible. Should look like
You should decide that for yourself. You can either add the records on your current nameservers, or switch nameservers at your registrar.
Ok. I will do it. I will go to ask the domain company to add my nameservers. After that, the SSL can work, right?
Apparently the domain server does not exist.
In this case, do i need to add my amazon’s nameservers where is domain registered, right?
This is my doubt.
Thanks for help.
If you use dns validation, you don't need a working website.
That's not required. Change your ns1.ptempresas.pt directly, if you use --manual.
