SSL error: sslv3 alert certificate unknown (in ssl3_read_bytes) With Autobahn Python Twisted on Ubuntu
My domain is: bernie-vs-trump.greenrobot.com
sudo python3 server.py
2020-02-10 01:13:58+0000 Log opened.
2020-02-10 01:13:58+0000 BroadcastServerFactory (TLS) starting on 9000
2020-02-10 01:13:58+0000 Starting factory <main.BroadcastServerFactory object at 0x7f6583a77780>
2020-02-10 01:14:00+0000 SSL error: sslv3 alert certificate unknown (in ssl3_read_bytes)
Apache. (Although this is a Python secure websocket server issue).
I am using Twisted Autobahn.
Ubuntu 18.
Here’s Mac
Linode.
no
certbot 0.31.0
Here’s my code. A whole lot of things, trying to get it working:
if __name__ == '__main__':
   import os
   from certifi import where
   os.environ['SSL_CERT_FILE'] = where()
   log.startLogging(sys.stdout)
   privkey=open('/etc/letsencrypt/live/bernie-vs-trump.greenrobot.com/privkey.pem', 'rt').read()
   certif=open('/etc/letsencrypt/live/bernie-vs-trump.greenrobot.com/cert.pem', 'rt').read()
   fullchain=open('/etc/letsencrypt/live/bernie-vs-trump.greenrobot.com/fullchain.pem', 'rt').read()
   from autobahn.twisted.websocket import WebSocketServerFactory
   KEYPATH2 = "/etc/letsencrypt/live/bernie-vs-trump.greenrobot.com/"
   tls_crt = os.path.join(KEYPATH2, "fullchain.pem")
   fullchain = os.path.join(KEYPATH2, "fullchain.pem")
   tls_key = os.path.join(KEYPATH2, "privkey.pem")
   contextFactory2 = twisted.internet.ssl.DefaultOpenSSLContextFactory(
        "/etc/letsencrypt/live/bernie-vs-trump.greenrobot.com/privkey.pem",
        "/etc/letsencrypt/live/bernie-vs-trump.greenrobot.com/cert.pem",
   contextFactory3 = certificateOptionsFromFiles(
    '/etc/letsencrypt/live/bernie-vs-trump.greenrobot.com/fullchain.pem')
   ServerFactory = BroadcastServerFactory
   factory = ServerFactory("wss://bernie-vs-trump.greenrobot.com:9000") #!!!!!!!!!!!!!!!!!!
   factory.protocol = MyServerProtocol
   autobahn.twisted.websocket.listenWS(factory, contextFactory3)
   #reactor.listenSSL(9000, factory, contextFactory)
   reactor.run()
When I try with:
reactor.listenTCP(9000, factory) instead of
and try to connect from Starscream on an iOS client, I get the following error:
dropping connection to peer tcp4:myip:50765 with abort=True: WebSocket opening handshake timeout (peer did not finish the opening handshake in time)
privkey = privkey.pem [yes]
certif = cert.pem [yes]
fullchain = fullchain.pem [not so sure about this - maybe it should use chain.pem file instead]
Also, I would try using fullchain.pem instead of cert.pem as in lines below:
I tried those two suggestions, and also switched from using contextFactory3 to contextFactory2 and get the same error:
sudo python3 serverssl.py
2020-02-10 12:14:13+0000 [-] Log opened.
2020-02-10 12:14:13+0000 [-] BroadcastServerFactory (TLS) starting on 9000
2020-02-10 12:14:13+0000 [-] Starting factory <__main__.BroadcastServerFactory object at 0x7fcfb761b780>
2020-02-10 12:14:15+0000 [-] SSL error: sslv3 alert certificate unknown (in ssl3_read_bytes)```
Wait, what does your SSL config look like for your domain virtual host or your global apache settings?
By current industry standards SSLv3 should be disabled, preferably anything below TLSv1.2:
SSL Protocol ALL -SSLv2 -SSLv3 -TLSv1 -TLSv1. 1
Well, this is with Twisted/Python, not Apache, isn't it? https works OK as far as I know. It's port 9000 running with Autobahn (GitHub - crossbario/autobahn-python: WebSocket and WAMP in Python for Twisted and asyncio)
For Apache, I tried:
openssl s_client -connect bernie-vs-trump.greenrobot.com:443 -ssl3
and got:
s_client: Option unknown option -ssl3
From: How to Disable SSLv3 in Linux (Ubuntu, CentOS, RedHat, Debian)
Thank you.
Should this test be for port 9000 (instead of 443)?
Testing both, I see that Apache answers on :443 and shows TLSv1.2:
curl -Iki https://bernie-vs-trump.greenrobot.com:443/
HTTP/1.1 200 OK
Date: Mon, 10 Feb 2020 16:44:22 GMT
Server: Apache/2.4.29 (Ubuntu)
New, TLSv1.2, Cipher is ECDHE-RSA-CHACHA20-POLY1305
While :9000 also shows TLSv1.2 but a different cipher:
 curl -Iki https://bernie-vs-trump.greenrobot.com:9000/
HTTP/1.1 405 HTTP method 'HEAD' not allowed
New, TLSv1.2, Cipher is ECDHE-RSA-AES256-GCM-SHA384
Hi there, I solved my problem via someone on Twisted IRC.
In Starscream websocket client, they are by default looking for cert pinning. This solved it:
OpenSSL reports weird errors. Apparently it is not using ssl v3 even though it reports using it.
Thanks for jumping in to help.
Simplified server sample code for anyone who stumbles across this:
   contextFactory = certificateOptionsFromFiles(
   factory = ServerFactory("wss://0.0.0.0:9000")
   reactor.listenSSL(9001, factory, contextFactory)
   reactor.run()
Client code:
        var request = URLRequest(url: URL(string: "wss://bernie-vs-trump.greenrobot.com:9000")!)
        request.timeoutInterval = 10
        // Sets the timeout for the connection
        self.socket = WebSocket(request: request, certPinner: nil)
        socket!.delegate = self
        socket!.connect()
