SSL doesn't work on phone
My domain is: hot-delivery.net
I ran this command: Deployed on vercel
It produced this output: ?
IDK - vercel configued
The operating system my web server runs on is (include version): IDK
My hosting provider, if applicable, is: Vercel
ITS NOT VPS! - so I don't have access to terminal
ITS NOT VPS
IDK
SSL certificate work on laptop
SSL certificate doesn't work on phone
Why?
How to fix it?
It works on my phone.
You will need to provide more information. What is the phone it doesn’t work on? Operating system and browser with versions would be best.
What is the exact error you get? Maybe with a screenshot.
Vercel support may be more equipped to help you as well.
Galaxy J3 (2016)
Model: SM-J320H
Android: 5.1.1
Chrome:95.0.4638.74
Your version of Android is too old to use current Let's Encrypt certificates. You need 7.1.1 or higher to trust the ISRG Root X1 root certificate (which was issued in June 2015) Certificate Compatibility - Let's Encrypt
The easiest workaround would be to try a different CA, but as vercel host your site I assume it's unlikely that you control that.
Presumably, devices that old would have trouble accessing much of the Internet (any site using Let's Encrypt), including sites like this forum?
They can use Firefox, or even install the appropriate root certificates in the system store, if possible.
