My domain is: Dont want SEO picking this up
My hosting provider, if applicable, is: GoDaddy
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Yes, GoDaddy cPanel
There’s no way that we could diagnose your problem from the limited information that you’ve provided.
In order to try to figure out what might be wrong, we’d like to be able to test the site for ourselves. In addition, we’d need to know the exact error message that you saw and which software produced that error message.
If you’re concerned about search engines penalizing you for posting a link to your domain on the forum, there should be lots of ways to address that. One is that you could use a character other than the dot, like “example,com” instead of “example.com”. Or separate the site name into multiple words, like “example com”.
You can also enclose text in backticks (the character `) to stop the forum software from generating a link or other formatting, like example.com (which isn’t a link).
I hope that helps, and I hope you’re able to share some specifics of your problem with us.
