Rookie Needs a SSL
My domain is: toolemail.com
I ran this command: where do I find an SSL here?
My web server is (include version): apache 2.4.43
The operating system my web server runs on is (include version): linux
My hosting provider, if applicable, is: godaddy
I can login to a root shell on my machine (yes or no, or I don’t know): i dont know
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): cpanel 78.0.49
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): i dont know
Looks like you are using GoDaddy’s cPanel shared hosting.
You can start by reading Let’s Encrypt’s post on GoDaddy first. https://letsencrypt.org/docs/godaddy/
This doesn’t mean you can’t get a certificate, it’s just means your process will be complex than normal.
For example, you can use certbot on your local machine and manually obtain one, or use acme.sh on GoDaddy’s shell to obtain one. Both are not as easy as regular “click and done” process…
Steven, thank you very much for your reply.
