SSL Certificate Not Working
My domain is: harmonyapp.org
I ran this command: sudo certbot --nginx
It produced this output: (thought_sync_django-channels) [ec2-user@ip-172-31-38-94 thought_sync_django-channels]$ sudo certbot --nginx
Enter email address (used for urgent renewal and security notices)
(Enter 'c' to cancel): malnatim@lafayette.edu
https://letsencrypt.org/documents/LE-SA-v1.4-April-3-2024.pdf. You must agree in
order to register with the ACME server. Do you agree?
(Y)es/(N)o: y
Would you be willing, once your first certificate is successfully issued, to
share your email address with the Electronic Frontier Foundation, a founding
partner of the Let's Encrypt project and the non-profit organization that
develops Certbot? We'd like to send you email about our work encrypting the web,
EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: y
Account registered.
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): harmonyapp.org
Requesting a certificate for harmonyapp.org
Domain: harmonyapp.org
Type: connection
Detail: 3.217.114.187: Fetching http://harmonyapp.org/.well-known/acme-challenge/0HeBIdmxMKy2YuXlbFJZVWwE3BHJSDn2iWcUVj0I2tg: Error getting validation data
My web server is (include version): AWS Amazon Linux 2023
The operating system my web server runs on is (include version): Centos7 (unsure)
My hosting provider, if applicable, is: (unsure)
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): No, I am using a terminal
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.11.0
You're using the --nginx plugin. Please make sure your nginx webserver is reachable on port 80 (HTTP) before trying to get a certificate.
Still same error
Still no working nginx (HTTP) webserver from my perspective.
Port 22 (SSH) and port 8001 seem to be open indeed, but no port 80 for HTTP.
Seems to be running on my end:
Also not working when testing with Let's Debug.
I see your CLI mentions some "internal" hostname with a private range IP address. Is there some weird routing/mapping required perhaps to make nginx publicly accessible? I'm not familiar with AWS Amazon myself, but maybe there needs to be done something else too.
Is port 80 not opened by my security group?
Also does the status show that nginx is reversed proxy or do I need to reverse proxy it myself? Will this make it publicly accessible?
That might not be enough. As said, I personally don't know anything about AWS.
If you mean the part after "Starting nginx.service", that's just the name/description of the nginx software.
No.
Let's check the public IP for your EC2 instance. It must match what is in the DNS
You can use the AWS EC2 console. Or, just show output of this command
curl -4 https://ifconfig.io
You had a rule allowing all ports inbound so shouldn't need one for just HTTP. Usually you do just allow certain ports and not use a catch-all inbound. So, there is something more going on here.
Should I remove the catch-all inbound for now or remove it later?
Later is fine. If you could copy/paste the data from your terminal to these posts that makes it easier for us. We often want to copy/paste your info to our own tools and using pics makes that harder.
So, what does this say
sudo ss -pant | grep -i listen | grep -Ei ':80|:443'
Like this? Let me know if you want to change the formatting:
LISTEN 0      511          0.0.0.0:80           0.0.0.0:*     users:(("nginx",pid=233737,fd=8),("nginx",pid=28208,fd=8))
LISTEN 0      511             [::]:80              [::]:*     users:(("nginx",pid=233737,fd=9),("nginx",pid=28208,fd=9))
Yes, thanks. I added 3 backticks before and after to get the nice scrolled-box effect. You get bonus points for that :slight_smile:
info
So, nginx is listening on port 80. So far the DNS, EC2 and nginx looks okay.
Did you setup iptables at all? What does this show?
sudo iptables --list
What is prot opt source? I assume we want that to say our port?
(thought_sync_django-channels) [ec2-user@ip-172-31-38-94 thought_sync_django-channels]$ sudo iptables --list
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
No, it's fine empty. That is for "fancy" things not the basic.
Hmmm. How did you setup the VPC? Did you make any VPC Network ACLs? Or firewall groups? Or, anything really?
It has been a long time since I setup my VPC so don't remember AWS defaults. Is yours a new AWS account?
The VPC console has these options (and more ...)
I may be forgetting what I did but from what I can remember I am using an Elsatic IP and a firewall
 sudo firewall-cmd --add-port=8001/tcp --permanent
Hang on. What's that then? Where did that command come from?
Are you running Docker containers?
I am not using Docker containers, I ran this on AWS
You probably also want to allow port 80 (HTTP) and port 443 (HTTPS).
Then you need to configure that firewall to also allow port 80 and port 443 (for HTTPS later)
Also any other ports you want inbound traffic on
I'll add that since you have EC2 Security Groups, and even VPC ACL Rules available, you don't need a firewall in the o/s itself. But, it's up to you as to how your organize and manage your system
