Good day, all.
I can't get the let's encrypt sertificate.
My domain is: cloud0.projectsk.ru
I ran this command: certbot --nginx
It produced this output: Certbot failed to authenticate some domains (authenticator: nginx). The Certificate Authority reported these problems: Domain: cloud0.projectsk.ru Type: connection Detail: 212.49.98.198: Fetching http://cloud0.projectsk.ru/.well-known/acme-challenge/DTWoGg4o3cTGGvj3z9ftTKvz07VPyNupTIznK-GCcjw: Connection refused
In log file /var/log/letsencrypt/letsencrypt.log:
Blockquote 2023-08-14 16:27:48,286:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/254870815726 HTTP/1.1" 200 1044
2023-08-14 16:27:48,287:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Mon, 14 Aug 2023 11:27:48 GMT
Content-Length: 1044
Boulder-Requester: 1250976346
Link: https://acme-v02.api.letsencrypt.org/directory;rel="index"
Replay-Nonce: 691VxMFkrL21l6WygG-ZiKGO3Ni5FAEK7fmFHh1IXDT2SFrZfIE
X-Frame-Options: DENY
"identifier": {
"type": "dns",
"value": "cloud0.projectsk.ru"
"status": "invalid",
"expires": "2023-08-21T11:27:45Z",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:connection",
"detail": "212.49.98.198: Fetching http://cloud0.projectsk.ru/.well-known/acme-challenge/DTWoGg4o3cTGGvj3z9ftTKvz07VPyNupTIznK-GCcjw: Connection refused",
"status": 400
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/254870815726/zhLY3A",
"token": "DTWoGg4o3cTGGvj3z9ftTKvz07VPyNupTIznK-GCcjw",
"validationRecord": [
"url": "http://cloud0.projectsk.ru/.well-known/acme-challenge/DTWoGg4o3cTGGvj3z9ftTKvz07VPyNupTIznK-GCcjw",
"hostname": "cloud0.projectsk.ru",
"port": "80",
"addressesResolved": [
"212.49.98.198"
"addressUsed": "212.49.98.198"
"validated": "2023-08-14T11:27:46Z"
2023-08-14 16:27:48,287:DEBUG:acme.client:Storing nonce: 691VxMFkrL21l6WygG-ZiKGO3Ni5FAEK7fmFHh1IXDT2SFrZfIE
2023-08-14 16:27:48,288:INFO:certbot._internal.auth_handler:Challenge failed for domain cloud0.projectsk.ru
2023-08-14 16:27:48,288:INFO:certbot._internal.auth_handler:http-01 challenge for cloud0.projectsk.ru
2023-08-14 16:27:48,288:DEBUG:certbot._internal.display.obj:Notifying user:
Type: connection
My web server is (include version): nginx version: nginx/1.22.1
nginx -T
configuration file /etc/nginx/sites-enabled/cloud.conf:
listen 80;
listen 443 ssl;
server_name cloud0.projectsk.ru;
if ($scheme = 'http') {
ssl_certificate /etc/nginx/ssl/cert.cert;
ssl_certificate_key /etc/nginx/ssl/cert.key;
root /var/www/cloud;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
client_max_body_size 10G;
fastcgi_buffers 64 4K;
rewrite ^/caldav(.*)$ /remote.php/caldav$1 redirect;
rewrite ^/carddav(.*)$ /remote.php/carddav$1 redirect;
rewrite ^/webdav(.*)$ /remote.php/webdav$1 redirect;
index index.php;
error_page 403 = /core/templates/403.php;
error_page 404 = /core/templates/404.php;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location ~ ^/(data|config|\.ht|db_structure\.xml|README) {
deny all;
#location /.well-known {
# root /var/www/cloud;
location ^~ /.well-known {
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }
location = /.well-known/webfinger { return 301 /index.php/.well-known/webfinger; }
location = /.well-known/nodeinfo { return 301 /index.php/.well-known/nodeinfo; }
location ^~ /.well-known{ return 301 /index.php/$uri; }
try_files $uri =404;
rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
rewrite ^(/core/doc/[^\/]+/)$ $1/index.html;
try_files $uri index.php;
location ~ ^(.+?\.php)(/.*)?$ {
try_files $1 = 404;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root$1;
fastcgi_param PATH_INFO $2;
fastcgi_param HTTPS on;
fastcgi_pass unix:/run/php/php8.2-fpm.sock;
location ~* ^.+\.(jpg|jpeg|gif|bmp|ico|png|css|js|swf)$ {
expires modified +30d;
access_log off;
The operating system my web server runs on is (include version): Debian 12.1
or certbot-auto --version
if you're using Certbot):certbot 2.1.0
