SSL-certificate not working DirectAdmin CentOS7
webconexus.cloud
Set-up SSL certificate in DirectAdmin
Requesting new certificate order…
Processing authorization for www.webconexus.cloud…
Error: http://www.webconexus.cloud/.well-known/acme-challenge/letsencrypt_1542973613 is not reachable. Aborting the script.
dig output for www.webconexus.cloud:
37.252.122.225
Please make sure /.well-known alias is setup in WWW server.
Apache
CentOS 7
Yes
DirectAdmin
Hello,
I try to set-up my SSL certificate but I am getting back this error. I set-up the .well-known folder, check it here:
http://www.webconexus.cloud/.well-known/acme-challenge/test.txt
My open firewall ports:
ports: 80/tcp 443/tcp 993/tcp 465/tcp 143/tcp 22/tcp 20/tcp 2222/tcp 995/tcp 587/tcp 25/tcp 110/tcp
DNS records:
2 times A
Someone knows what I am doing wrong here? Thanks in advance.
Regards,
Roef
Lol totally forgot to use this command:
cd /usr/local/directadmin/custombuild
./build rewrite_confs
I was under the impression that custombuild 2.0 already had this done. But it’s working now
and
http://webconexus.cloud/.well-known/acme-challenge/test.txt
Return 404 errors.
