Ssl certificate issue
My domain is:dev.api.amepos.io
I ran this command: salt which renews certificate
It produced this output:success
My web server is (include version):nginx
The operating system my web server runs on is (include version):debian
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot
What is the issue?
If it is this:
What shows?:
certbot certificates
It should show a renewed cert:
If so, then you only need to restart/reload the web service [so that it can use the latest cert].
yes, i restarted the webserver still website is showing ssl certification is expired
Please show the nginx configuration, with:
nginx -T
nginx -T
certbot renew --cert-name "dev.api.amepos.io" --deploy-hook "service nginx reload"
Processing /etc/letsencrypt/renewal/dev.api.amepos.io.conf
Cert not yet due for renewal
The following certificates are not due for renewal yet:
/etc/letsencrypt/live/dev.api.amepos.io/fullchain.pem expires on 2024-01-28 (skipped)
No renewals were attempted.
No hooks were run.
Are you sure you used the capital T? Because usually the capital T would output the entire parsed nginx configuration and not just the two syntax check results.
nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
	worker_connections 768;
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	types_hash_max_size 2048;
	# server_tokens off;
	# SSL Settings
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
	ssl_prefer_server_ciphers on;
	# Logging Settings
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
	# gzip_comp_level 6;
	# gzip_buffers 16 8k;
	# gzip_http_version 1.1;
	# Virtual Host Configs
#mail {
#	# See sample authentication script at:
#	# http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#	# auth_http localhost/auth.php;
#	# pop3_capabilities "TOP" "USER";
#	# imap_capabilities "IMAP4rev1" "UIDPLUS";
#	server {
#		listen     localhost:110;
#		protocol   pop3;
#		proxy      on;
#	server {
#		listen     localhost:143;
#		protocol   imap;
#		proxy      on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
# configuration file /etc/nginx/modules-enabled/70-mod-stream-geoip.conf:
load_module modules/ngx_stream_geoip_module.so;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/proxy_params:
proxy_set_header Host $http_host;
# configuration file /etc/nginx/sites-enabled/dev.api.amepos.io.conf:
    listen          80;
    server_name     dev.api.amepos.io;
    # ACME http challenges
      root /var/www/html;     # matches name in certbot webroot folder
    # Redirect all others
    listen 443 ssl http2;
    listen [::]:443 ssl http2;
    ssl_certificate /etc/letsencrypt/live/dev.api.amepos.io/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/dev.api.amepos.io/privkey.pem;
    ssl_session_timeout 1d;
    ssl_session_cache shared:MozSSL:10m;  # about 40000 sessions
    ssl_session_tickets off;
    # curl https://ssl-config.mozilla.org/ffdhe2048.txt > /path/to/dhparam
    # ssl_dhparam /etc/nginx/ssl/dhparam;
    # intermediate configuration
    ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
    ssl_prefer_server_ciphers off;
    # HSTS (ngx_http_headers_module is required) (63072000 seconds)
    add_header Strict-Transport-Security "max-age=63072000" always;
    ssl_trusted_certificate /etc/letsencrypt/live/dev.api.amepos.io/chain.pem;
    # OCSP stapling
    ssl_stapling on;
    ssl_stapling_verify on;
    resolver 8.8.8.8 8.8.4.4 valid=300s;
    resolver_timeout 5s;
    location /static {
        alias   /var/www/html/amepos_backend_apis/development/static_root;
    location /media {
        alias   /var/www/html/amepos_backend_apis/development/media_root;
        include proxy_params;
        proxy_pass http://127.0.0.1:5565;
    error_page   500 502 503 504  /50x.html;
    location = /50x.html {
        root   /usr/share/nginx/html;
    access_log /var/log/nginx/dev.api.amepos.io.access;
    error_log /var/log/nginx/dev.api.amepos.io.error;
Please run sudo systemctl reload nginx
Thank you so much solved the issue
Interesting. I'm glad the issue has been fixed, but I'm puzzled it was not fixed before when you said:
:man_shrugging:
