Certificate expired (Certificate not yet due for renewal)
phone.teomanga.org.nz
certbot renew and sudo certbot renew
nginx 1.10.3-1+deb9u2
Debian 9
Yes
No
certbot 0.28.0
From my perspective, https://phone.teomanga.org.nz/ is using a certificate for remote.teomanga.org.nz issued by GoDaddy that expires in 2020. Plus it’s a Microsoft IIS server, not Nginx.
It doesn’t match, but it’s also not expired.
What software is saying what URL is expired?
Has Nginx been reloaded or restarted since the certificate was renewed in February? (If the certificate was created with certbot --nginx, Certbot would do this automatically.)
What certificate and key files are Nginx configured to use?
That’s on port 443, sorry I should have added that this cert is running on port 5001
Oh. That makes sense. :smile: Yes, I see the expired certificate on the Nginx server on https://phone.teomanga.org.nz:5001/.
As you can see in the screenshot I originally attached certbot acknowledges that the certificate expires 05/03/2019
The server time and my local time is 05/03/2019
But it also says it’s not due for renewal today…
The certificate expires May 3. That’s what Certbot is saying.
What certificate-related files is your nginx configuration pointed at? Did you set up that configuration manually after you got your certificate?
Do you remember – or still have a record of – the command used to create the certificate originally?
-sigh- thanks everyone for your help but I can confirm that this was a Layer 8 issue.
I was reading 5/3 as 5th of march (today)
Not 3rd of May, which it is…
Nginx was configured to the wrong certificates
