SSL Certificate generated and seems to be OK, but browser gives ERR_SSL_PROTOCOL_ERROR
I created a certificate for (yet) internal server, the ssl certificate seems to be OK (For example if i use the certificate in my adguard home (for encryption): Adguard home states the following:
Status:
And for the key:
  • This is a valid ECDSA private key
However if try to access it via my browser in my network, the browser gives the ERR_SSL_PROTOCOL_ERROR message and will not continue.
If i look at crt.sh ( crt.sh | 8739541196) : I see the status is "precertficate". Is that the problem, and if so how can i avoid this.
coenjaerts.net (certificate was generated for arrakis.coenjaerts.net)
certbit certonly --dns-cloudflare --dns-cloudflare-credentials ~/.secrets/certbot/cloudflare.ini --dns-cloudflare-propagation-seconds 60 -d arrakis.coenjaerts.net
Found the following certs:
Certificate Name: arrakis.coenjaerts.net
Serial Number: 49cf47d11fcaf50ec9347ef9e7f742ef951
Key Type: ECDSA
Domains: arrakis.coenjaerts.net
Expiry Date: 2023-05-26 12:34:43+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/arrakis.coenjaerts.net/fullchain.pem
Private Key Path: /etc/letsencrypt/live/arrakis.coenjaerts.net/privkey.pem
Built in webserver of adguard home
Arch linux x64
N/A internally hosted
N/A
certbot 2.3.0
No, that's not the problem. Pre-certs are part of the way LE gets the "Signed Certificate Timestamp" (SCT) from the Certificate Transparancy Log. You were issued a real certificate with the SCTs received from the CT logs using the pre-cert.
That said, I have no clue about Adguard Home and your server is internal, so no way to debug it remotely. Thus, just guessing here, but perhaps it has something to do with the cert being ECDSA instead of RSA? Although you say Adguard Home reports a valid ECDSA key so one should assume Adguard can deal with that..
Thx, I solved the problem (stupid me). In non-https, I configured that for the web interface port 3000 should be used (so I could access it via http://arrakis.coenjaerts.net:3000). After I activated the encryption, I only changed the http into https, so the encrypted connection still tried to access via port 3000. This obviously does not work. The moment I leave out the port number (so https://arrakis.coenjaerts.net), it works, as the default 443 is used.
