SSL Cert Renew Process
I don’t think I know enough about EVE to solve that.
Maybe adding this could help? But it’s a total guess.
<Directory "/opt/unetlab/html">
  Require all granted
</Directory>
Are you otherwise able to get remote access again via https://lab.addmoreroutes.com/html5/ ?
anyway of restoring to a previous backup ?
Yup, you can copy the contents of the config files from one of the checkpoints in /var/lib/letsencrypt/backups, such as 1564724652.18 (which is from August 2nd).
You will need to match each file in there with the one in your /etc/apache2/sites-available directory.
There’s no automated way to revert, though.
what is the step by step process ? or manual way
I see duplicated text:
        <FilesMatch "\.(cgi|shtml|phtml|php)$">
                SSLOptions +StdEnvVars
        </FilesMatch>
        <Directory /usr/lib/cgi-bin>
        </Directory>
        <Location /html5/>
                Order allow,deny
                Allow from all
                ProxyPass http://127.0.0.1:8080/guacamole/ flushpackets=on
                ProxyPassReverse http://127.0.0.1:8080/guacamole/
        </Location>
        <Location /html5/websocket-tunnel>
                Order allow,deny
                Allow from all
                ProxyPass ws://127.0.0.1:8080/guacamole/websocket-tunnel
                ProxyPassReverse ws://127.0.0.1:8080/guacamole/websocket-tunnel
        </FilesMatch>
        </Directory>
        <Location /html5/>
                Order allow,deny
                Allow from all
        </Location>
                Order allow,deny
                Allow from all
        </Location>
root@eve-ng:/var/lib/letsencrypt/backups# ls
1555944269.91 1564724652.18 1564724695.83 1572882973.69 1572882985.02
A post was merged into an existing topic: Renew SSL Certificate on Google DSN
I think I messed up on the post but I double checked and there is no duplicate texts
Any thoughts on how to go about restoring from a backup ?
