Problem to renew certificate
Good
I am having the same problem as some other users. I have only been able to renew the mail certificate.
I provide the following data.
I tried to disable the https, the file list and removed the custom 404 web.
sorienrot.es
certbot renew
root@sorienrot:~# certbot renew
Processing /etc/letsencrypt/renewal/mail.sorienrot.es.conf
Cert not yet due for renewal
Processing /etc/letsencrypt/renewal/sorienrot.es.conf
http-01 challenge for sorienrot.es
Attempting to renew cert (sorienrot.es) from /etc/letsencrypt/renewal/sorienrot.es.conf produced an unexpected error: Failed authorization procedure. sorienrot.es (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://sorienrot.es/.well-known/acme-challenge/Yr3fMaGMfzbp9MSAxi8281Bu0KMTzmhMMeNlWYfuBqI [164.132.204.91]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">\n<html><head>\n<title>404 Not Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p". Skipping.
  /etc/letsencrypt/live/sorienrot.es/fullchain.pem (failure)
  /etc/letsencrypt/live/mail.sorienrot.es/fullchain.pem expires on 2019-06-29 (skipped)
   Domain: sorienrot.es
   Type:   unauthorized
   Detail: Invalid response from
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2019-04-03T13:22:37
Ubuntu 18.04.1 LTS
Linux ubuntu 4.15.0-44-generic #47-Ubuntu SMP Mon Jan 14 11:26:59 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
OVH Dedicated Server
Yes
No
root@sorienrot:~# certbot --version
certbot 0.31.0
Extra information
<VirtualHost *:80>
	DocumentRoot /var/www/html
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
	<Directory "/var/www/html">
    		AllowOverride All
	</Directory>
root@sorienrot:~# apache2ctl -M | grep rewrite
     rewrite_module (shared)
    root@sorienrot:~# grep -ri 'sorienrot.es' /etc/apache2/*
    /etc/apache2/sites-available/mail.sorienrot.es-le-ssl.conf:        ServerName mail.sorienrot.es
    /etc/apache2/sites-available/mail.sorienrot.es-le-ssl.conf:        DocumentRoot /var/www/mail.sorienrot.es
    /etc/apache2/sites-available/mail.sorienrot.es-le-ssl.conf:SSLCertificateFile /etc/letsencrypt/live/mail.sorienrot.es/fullchain.pem
    /etc/apache2/sites-available/mail.sorienrot.es-le-ssl.conf:SSLCertificateKeyFile /etc/letsencrypt/live/mail.sorienrot.es/privkey.pem
    /etc/apache2/sites-available/sorienrot.es-le-ssl.conf:  ServerName sorienrot.es
    /etc/apache2/sites-available/sorienrot.es-le-ssl.conf:  ServerAdmin soporte@sorienrot.es
    /etc/apache2/sites-available/sorienrot.es-le-ssl.conf:# RewriteCond %{SERVER_NAME} =sorienrot.es
    /etc/apache2/sites-available/sorienrot.es-le-ssl.conf:SSLCertificateFile /etc/letsencrypt/live/sorienrot.es/fullchain.pem
    /etc/apache2/sites-available/sorienrot.es-le-ssl.conf:SSLCertificateKeyFile /etc/letsencrypt/live/sorienrot.es/privkey.pem
    /etc/apache2/sites-available/sorienrot.es.conf: ServerName sorienrot.es
    /etc/apache2/sites-available/sorienrot.es.conf: ServerAdmin soporte@sorienrot.es
    /etc/apache2/sites-available/sorienrot.es.conf:RewriteCond %{SERVER_NAME} =sorienrot.es
    /etc/apache2/sites-available/mail.sorienrot.es.conf:        ServerName mail.sorienrot.es
    /etc/apache2/sites-available/mail.sorienrot.es.conf:        DocumentRoot /var/www/mail.sorienrot.es
    /etc/apache2/sites-available/mail.sorienrot.es.conf:RewriteCond %{SERVER_NAME} =mail.sorienrot.es
    /etc/apache2/sites-available/default-ssl.conf:          SSLCertificateFile /etc/letsencrypt/live/sorienrot.es/fullchain.pem
    /etc/apache2/sites-available/default-ssl.conf:          SSLCertificateKeyFile /etc/letsencrypt/live/sorienrot.es/privkey.pem
    root@sorienrot:~# apache2ctl configtest
    Syntax OK
    root@sorienrot:~#
Hi @sorienrot
checking your domain via https://check-your-website.server-daten.de/?q=sorienrot.es there is a redirect http -> https.
164.132.204.91 302 https://sorienrot.es/ 9.044 A
http://www.sorienrot.es/
164.132.204.91 302 https://www.sorienrot.es/ 0.040 A
164.132.204.91 200 0.306 N
Certificate error: RemoteCertificateChainErrors
164.132.204.91 200 0.297 N
Certificate error: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
No Signal 404 Error Page
164.132.204.91 302 No Signal 404 Error Page 0.043 A
Visible Content: Found The document has moved here . Apache/2.4.29 (Ubuntu) Server at sorienrot.es Port 80
http://www.sorienrot.es/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
164.132.204.91 302 No Signal 404 Error Page 0.044 A
Visible Content: Found The document has moved here . Apache/2.4.29 (Ubuntu) Server at www.sorienrot.es Port 80
No Signal 404 Error Page 404 0.203 N
Not Found
Visible Content: Not Found The requested URL /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de was not found on this server. Apache/2.4.29 (Ubuntu) Server at sorienrot.es Port 443
No Signal 404 Error Page 404 0.207 N
Not Found
That's ok, Letsencrypt follows these redirects.
You have shared the DocumentRoot of your port 80 vHost.
Has the port 443 vHost of that domain the same DocumentRoot?
Find that - and use it.
certbot run -a webroot -i apache -w yourPort443Webroot -d www.sorienrot.es -d sorienrot.es
This?
default-ssl.conf
<IfModule mod_ssl.c>
	<VirtualHost _default_:443>
		# error, crit, alert, emerg.
		# modules, e.g.
		#LogLevel info ssl:warn
		#   SSL Engine Switch:
		#   Enable/Disable SSL for this virtual host.
		SSLEngine on
		#   A self-signed (snakeoil) certificate can be created by installing
		#   the ssl-cert package. See
		#   /usr/share/doc/apache2/README.Debian.gz for more info.
		#   If both key and certificate are stored in the same file, only the
		#   SSLCertificateFile directive is needed.
		#   Server Certificate Chain:
		#   Point SSLCertificateChainFile at a file containing the
		#   concatenation of PEM encoded CA certificates which form the
		#   certificate chain for the server certificate. Alternatively
		#   the referenced file can be the same as SSLCertificateFile
		#   when the CA certificates are directly appended to the server
		#   certificate for convinience.
		#SSLCertificateChainFile /etc/apache2/ssl.crt/server-ca.crt
		#   Certificate Authority (CA):
		#   Set the CA certificate verification path where to find CA
		#   certificates for client authentication or alternatively one
		#   huge file containing all of them (file must be PEM encoded)
		#   Note: Inside SSLCACertificatePath you need hash symlinks
		#		 to point to the certificate files. Use the provided
		#		 Makefile to update the hash symlinks after changes.
		#SSLCACertificatePath /etc/ssl/certs/
		#SSLCACertificateFile /etc/apache2/ssl.crt/ca-bundle.crt
		#   Certificate Revocation Lists (CRL):
		#   Set the CA revocation path where to find CA CRLs for client
		#   authentication or alternatively one huge file containing all
		#   of them (file must be PEM encoded)
		#   Note: Inside SSLCARevocationPath you need hash symlinks
		#SSLCARevocationPath /etc/apache2/ssl.crl/
		#SSLCARevocationFile /etc/apache2/ssl.crl/ca-bundle.crl
		#   Client Authentication (Type):
		#   Client certificate verification type and depth.  Types are
		#   none, optional, require and optional_no_ca.  Depth is a
		#   number which specifies how deeply to verify the certificate
		#   issuer chain before deciding the certificate is not valid.
		#SSLVerifyClient require
		#SSLVerifyDepth  10
		#   SSL Engine Options:
		#   Set various options for the SSL engine.
		#   o FakeBasicAuth:
		#	 Translate the client X.509 into a Basic Authorisation.  This means that
		#	 the standard Auth/DBMAuth methods can be used for access control.  The
		#	 user name is the `one line' version of the client's X.509 certificate.
		#	 Note that no password is obtained from the user. Every entry in the user
		#	 file needs this password: `xxj31ZMTZzkVA'.
		#   o ExportCertData:
		#	 This exports two additional environment variables: SSL_CLIENT_CERT and
		#	 SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
		#	 server (always existing) and the client (only existing when client
		#	 authentication is used). This can be used to import the certificates
		#	 into CGI scripts.
		#   o StdEnvVars:
		#	 This exports the standard SSL/TLS related `SSL_*' environment variables.
		#	 Per default this exportation is switched off for performance reasons,
		#	 because the extraction step is an expensive operation and is usually
		#	 useless for serving static content. So one usually enables the
		#	 exportation for CGI and SSI requests only.
		#   o OptRenegotiate:
		#	 This enables optimized SSL connection renegotiation handling when SSL
		#	 directives are used in per-directory context.
		#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
		<FilesMatch "\.(cgi|shtml|phtml|php)$">
				SSLOptions +StdEnvVars
		</FilesMatch>
		<Directory /usr/lib/cgi-bin>
		</Directory>
		#   SSL Protocol Adjustments:
		#   The safe and default but still SSL/TLS standard compliant shutdown
		#   approach is that mod_ssl sends the close notify alert but doesn't wait for
		#   the close notify alert from client. When you need a different shutdown
		#   approach you can use one of the following variables:
		#   o ssl-unclean-shutdown:
		#	 This forces an unclean shutdown when the connection is closed, i.e. no
		#	 SSL close notify alert is send or allowed to received.  This violates
		#	 the SSL/TLS standard but is needed for some brain-dead browsers. Use
		#	 this when you receive I/O errors because of the standard approach where
		#	 mod_ssl sends the close notify alert.
		#   o ssl-accurate-shutdown:
		#	 This forces an accurate shutdown when the connection is closed, i.e. a
		#	 SSL close notify alert is send and mod_ssl waits for the close notify
		#	 alert of the client. This is 100% SSL/TLS standard compliant, but in
		#	 practice often causes hanging connections with brain-dead browsers. Use
		#	 this only for browsers where you know that their SSL implementation
		#	 works correctly.
		#   Notice: Most problems of broken clients are also related to the HTTP
		#   keep-alive facility, so you usually additionally want to disable
		#   keep-alive for those clients, too. Use variable "nokeepalive" for this.
		#   Similarly, one has to force some clients to use HTTP/1.0 to workaround
		#   their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
		#   "force-response-1.0" for this.
		# BrowserMatch "MSIE [2-6]" \
		#		nokeepalive ssl-unclean-shutdown \
		#		downgrade-1.0 force-response-1.0
	</VirtualHost>
</IfModule>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
<VirtualHost *:443>
	# specifies what hostname must appear in the request's Host: header to
	#ServerName www.example.com
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
    		AllowOverride All
	</Directory>
	# modules, e.g.
</VirtualHost>
</IfModule>
So it’s the same webroot.
certbot run -a webroot -i apache -w /var/www/html -d www.sorienrot.es -d sorienrot.es
Which virtual host would you like to choose?
1: mail.sorienrot.es-le-ssl.conf  | mail.sorienrot.es     | HTTPS | Enabled
2: glpi.conf                      | glpi.ochobitunbyte.pw |       | Enabled
3: 000-default.conf               |                       |       | Enabled
4: sorienrot.es-le-ssl.conf       | sorienrot.es          | HTTPS | Enabled
5: sorienrot.es.conf              | sorienrot.es          |       | Enabled
6: mail.sorienrot.es.conf         | mail.sorienrot.es     |       | Enabled
7: default-ssl.conf               |                       | HTTPS | Enabled
4 or 5?
Oh, what’s that?
Looks like Certbot shows new options :wink:
If you use 5, maybe Certbot creates a new port 443 vHost.
So choose 4, the existing vHost should be configured with the new certificate.
It works now. Thank you very much for the help.
For the future renewal should I do the same or just do the cerbot renew command?
Certbot should save your input in the configuration files. So renew should work.
