Ssl activation problem NET::ERR_CERT_AUTHORITY_INVALID
dubbie.tech
/root/.acme.sh/acme.sh --issue -d dubbie.tech -d www.dubbie.tech --cert-file /etc/letsencrypt/live/dubbie.tech/cert.pem --key-file /etc/letsencrypt/live/dubbie.tech/privkey.pem --fullchain-file /etc/letsencrypt/live/dubbie.tech/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
Verifying: dubbie.tech
Pending, The CA is processing your order, please just wait. (1/30)
Please refer to libcurl - Error Codes for error code: 35
dubbie.tech:Verify error:
Please add '--debug' or '--log' to check more details.
See: How to debug acme.sh · acmesh-official/acme.sh Wiki · GitHub
php 7.3
Ubuntu 20.04
Contabo
Cyberpanel
Please do this.
I got this:
Your server is returning a 502 http error code. It does this even for "home page" requests and is not related to Let's Encrypt. You should first fix your server and then try acme.sh after that. The 502 is usually something wrong with your proxy_pass
curl -I http://dubbie.tech
HTTP/1.1 502 Bad Gateway
Server: nginx/1.18.0 (Ubuntu)
Date: Tue, 27 Sep 2022 14:10:33 GMT
Content-Type: text/html
Content-Length: 166
Further, you should change your port 80 nginx server block to process the acme-challenge requests without sending to the proxy
