Spurious 301 after changing IP address
tana.it
certbot -v renew
Domain: tana.it
Type: connection
Detail: 185.199.25.198: Fetching
http://www.tana.it/.well-known/acme-challenge/GHyXUtNIbDvFr2rirr5S4RlZDU4_kHrG5KAu7NGMMgM:
Apache/2.4.56 (Debian)
Devuan Chimaera (equiv. Debian 11.1)
Altitud
no
certbot 1.12.0
The "only" thing I changed since last renewal is the IP number of the server. Now it is 185.199.25.198, which internally is NATted to 192.168.1.254. The redirection from tana.it to www.tana.it has been there for quite some time. Yet, I find the request for tana.it but not the redirected one:
3.135.199.140 42526 - [27/Mar/2023:17:43:35 +0200] "GET /.well-known/acme-challenge/GHyXUtNIbDvFr2rirr5S4RlZDU4_kHrG5KAu7NGMMgM HTTP/1.1" "-" 301 394 "tana.it [192.168.1.254]" tana.it "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)" "-"
23.178.112.208 51358 - [27/Mar/2023:17:43:35 +0200] "GET /.well-known/acme-challenge/GHyXUtNIbDvFr2rirr5S4RlZDU4_kHrG5KAu7NGMMgM HTTP/1.1" "-" 301 394 "tana.it [192.168.1.254]" tana.it "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)" "-"
18.236.139.1 61602 - [27/Mar/2023:17:43:35 +0200] "GET /.well-known/acme-challenge/GHyXUtNIbDvFr2rirr5S4RlZDU4_kHrG5KAu7NGMMgM HTTP/1.1" "-" 301 394 "tana.it [192.168.1.254]" tana.it "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)" "-"
Well using Let's Debug yields https://letsdebug.net/www.tana.it/1423104; seems to be IPv6 related
AAAANotWorking
Error
www.tana.it has an AAAA (IPv6) record (2a06:a003:e016::2) but a test request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address. You should either ensure that validation requests to this domain succeed over IPv6, or remove its AAAA record.
A timeout was experienced while communicating with www.tana.it/2a06:a003:e016::2: Get "http://www.tana.it/.well-known/acme-challenge/letsdebug-test": context deadline exceeded
Trace:
@0ms: Making a request to http://www.tana.it/.well-known/acme-challenge/letsdebug-test (using initial IP 2a06:a003:e016::2)
@0ms: Dialing 2a06:a003:e016::2
@10000ms: Experienced error: context deadline exceeded
Although the failure is via IPv4:
I do see an issue with IPv6 [with one of the names]:
Addresses: 2a06:a003:e016::2
           185.199.25.198
Address:  185.199.25.198
curl -Ii4 http://tana.it/.well-known/acme-challenge/GHyXUtNIbDvFr2rirr5S4RlZDU4_kHrG5KAu7NGMMgM
Date: Mon, 27 Mar 2023 16:00:56 GMT
Server: Apache
Location: http://www.tana.it/.well-known/acme-challenge/GHyXUtNIbDvFr2rirr5S4RlZDU4_kHrG5KAu7NGMMgM
curl -Ii4 http://www.tana.it/.well-known/acme-challenge/GHyXUtNIbDvFr2rirr5S4RlZDU4_kHrG5KAu7NGMMgM
HTTP/1.1 404 Not Found
Date: Mon, 27 Mar 2023 16:01:03 GMT
Server: Apache
curl -Ii6 http://www.tana.it/.well-known/acme-challenge/GHyXUtNIbDvFr2rirr5S4RlZDU4_kHrG5KAu7NGMMgM
I see... Route48.org, which provided the IPv6 link said they're closing down. I hoped that would have lasted until I get new IPv6 addresses, but it didn't. Now I've deleted them. By tomorrow it should work with IPv4 only...
Thank you!
Also DNS Spy report for tana.it shows www.tana.it has IPv4 & IPv6 Addresses where tana.it only has an IPv4 Address.
Do you use any GeoLocation type blocks?
OR any other type of IP blocking?
Let's Encrypt uses the authoritive servers and those look ok already.
nslookup www.tana.it dns2.zoneedit.com
(Note: No IPV6 record)
And now Let's Debug is OK https://letsdebug.net/www.tana.it/1423133
Yup, it worked, bypassing any DSN cache. Great!
