Continuing the discussion from Internationalized Domain Names:
I think that the Issuance & Renewal category is a bit broad, and should be split into two categories.
One category for technical & client problems with issuance/renewal, the second category for policy decisions: the above topic, and things like "how often do certificates last", "when should a certificate be renewed".
Examples:
Implementation
Re-run Letsencrypt Client installs on existing installations? - #3 by eva2000
Manual authenticator - way to automate the ACME Challenge file creation? - #3 by eva2000
LE replacing a current certificate - #22 by schoen
Preventing a attacker with DNS control from issueing certificates - #6 by schoen
Letsencrypt & FreeBSD -
Issuance Policy
Internationalized Domain Names - #20 by eih
Are they limitations on who can use Let's Encrypt? - #5 by josh
How do you confirm the person asking for the certificate actually owns the domain? - #20 by schoen
Client auto renewals and failure notifications? - #5 by schoen
Shouldn't verification via DNS record be a priority? - #7 by shred
I think 5 examples of each type is enough ![]()
Would like suggestions on the names.
@jsha what say you?
