Hello Community,
our Sophos UTM v. 9.714-4 worked fine until 2 weeks ago.
The update to renew our wildcard-certificate fails.
Below the log. I have already tried several ways, but it no longer works.
Does anyone know what the error could be ?
Note: as had tried it as wildcard as well with the individual subdomains.
2023:03:03-11:23:02 mail-1 letsencrypt[14080]: I Renew certificate: handling CSR REF_CaCsrWildcardsc for domain set [all subdomains that should be included in the certificate]
2023:03:03-11:23:02 mail-1 letsencrypt[14080]: I Renew certificate: running command: /var/storage/chroot-reverseproxy/usr/dehydrated/bin/dehydrated -x -f /var/storage/chroot-reverseproxy/usr/dehydrated/conf/config -c --accept-terms --domain --domain mysub.domain.net
2023:03:03-11:24:01 mail-1 letsencrypt[18497]: E Renew certificate: aborting, failed to acquire an exclusive lock: Resource temporarily unavailable
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: I Renew certificate: command completed with exit code 256
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ERROR: Challenge is invalid! (returned: invalid) (result: ["type"] "http-01"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["status"] "invalid"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["error","type"] "urn:ietf:params:acme:error:unauthorized"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["error","detail"] "195.20.225.163: Invalid response from https://autodiscover.1and1.info/Autodiscover/Autodiscover.xml: 405"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["error","status"] 403
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["error"] {"type":"urn:ietf:params:acme:error:unauthorized","detail":"195.20.225.163: Invalid response from https://autodiscover.1and1.info/Autodiscover/Autodiscover.xml: 405","status":403}
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["url"] "https://acme-v02.api.letsencrypt.org/acme/chall-v3/207844815786/iq04ZA"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["token"] "Y_iPh5mIectU8pYuRgOaUVaWV95_ApICGnFApGhLkeU"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"url"] "http://autodiscover.our-domain.net/.well-known/acme-challenge/Y_iPh5mIectU8pYuRgOaUVaWV95_ApICGnFApGhLkeU"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"hostname"] "autodiscover.our-domain.net"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"port"] "80"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"addressesResolved",0] "195.20.225.163"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"addressesResolved"] ["195.20.225.163"]
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0,"addressUsed"] "195.20.225.163"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",0] {"url":"http://autodiscover.our-domain.net/.well-known/acme-challenge/Y_iPh5mIectU8pYuRgOaUVaWV95_ApICGnFApGhLkeU","hostname":"autodiscover.our-domain.net","port":"80","addressesResolved":["195.20.225.163"],"addressUsed":"195.20.225.163"}
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",1,"url"] "https://autodiscover.1and1.info/Autodiscover/Autodiscover.xml"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",1,"hostname"] "autodiscover.1and1.info"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",1,"port"] "443"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",1,"addressesResolved",0] "195.20.225.162"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",1,"addressesResolved"] ["195.20.225.162"]
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",1,"addressUsed"] "195.20.225.162"
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord",1] {"url":"https://autodiscover.1and1.info/Autodiscover/Autodiscover.xml","hostname":"autodiscover.1and1.info","port":"443","addressesResolved":["195.20.225.162"],"addressUsed":"195.20.225.162"}
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validationRecord"] [{"url":"http://autodiscover.our-domain.net/.well-known/acme-challenge/Y_iPh5mIectU8pYuRgOaUVaWV95_ApICGnFApGhLkeU","hostname":"autodiscover.our-domain.net","port":"80","addressesResolved":["195.20.225.163"],"addressUsed":"195.20.225.163"},{"url":"https://autodiscover.1and1.info/Autodiscover/Autodiscover.xml","hostname":"autodiscover.1and1.info","port":"443","addressesResolved":["195.20.225.162"],"addressUsed":"195.20.225.162"}]
2023:03:03-11:24:50 mail-1 letsencrypt[14080]: E Renew certificate: COMMAND_FAILED: ["validated"] "2023-03-03T10:24:47Z")
2023:03:03-11:24:51 mail-1 letsencrypt[14080]: I Renew certificate: sending notification WARN-603
2023:03:03-11:24:51 mail-1 letsencrypt[14080]: [WARN-603] Let's Encrypt certificate renewal failed accessing Let's Encrypt service
2023:03:03-11:24:51 mail-1 letsencrypt[14080]: I Renew certificate: execution completed (CSRs renewed: 0, failed: 1)
