My domain is: nblp.moph.go.th
I ran this command:certbot --apache
1: nblp.moph.go.th
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/000-default-le-ssl.conf
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Created redirect file: le-redirect-nblp.moph.go.th.conf
Rollback checkpoint is empty (no changes made?)
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: https://nblp.moph.go.th
https://www.ssllabs.com/ssltest/analyze.html?d=nblp.moph.go.th
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/nblp.moph.go.th-0002/fullchain.pem
/etc/letsencrypt/live/nblp.moph.go.th-0002/privkey.pem
Your cert will expire on 2023-09-20. To obtain a new or tweaked
with the "certonly" option. To non-interactively renew all of
your certificates, run "certbot renew" -
Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
root@nblp:/etc/apache2/sites-available# cd /etc/letsencrypt/live/
My web server is (include version):apache // ubuntu20.04
The operating system my web server runs on is (include version): ubuntu20.04
My hosting provider, if applicable, is: my own.
I can login to a root shell on my machine (yes or no, or I don't know): yes.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):0.40
