I used docker-compose, which ran Nginx proxy server, my ASP.NET Core app and Certbot.
Then I got from Certbot following response:
http-01 challenge for velcoro.xyz
http-01 challenge for www.velcoro.xyz
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification…
Challenge failed for domain www.velcoro.xyz
Challenge failed for domain velcoro.xyz
