[solved] SSL for primary domain and multiple subdomains
My domain is: sympliving.com
sudo certbot run --apache --webroot-path=/var/www/live/public -d sympliving.com --renew-by-default -w /var/www/dev/public -d dev.sympliving.com -w /var/www/blog -d blog.sympliving.com
tls-sni-01 challenge for sympliving.com
tls-sni-01 challenge for dev.sympliving.com
tls-sni-01 challenge for blog.sympliving.com
Failed authorization procedure. dev.sympliving.com (tls-sni-01): urn:acme:error:malformed :: The request message was malformed :: Server only speaks HTTP, not TLS, blog.sympliving.com (tls-sni-01): urn:acme:error:malformed :: The request message was malformed :: Server only speaks HTTP, not TLS
   Domain: dev.sympliving.com
   Type:   malformed
   Detail: Server only speaks HTTP, not TLS
   Domain: blog.sympliving.com
   Type:   malformed
   To fix these errors, please make sure that you did not provide any
   invalid information to the client, and try running Certbot again.
My web server is (include version): Apache/2.4.25 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 17.04
My hosting provider, if applicable, is: Google Compute Engine
hi @kneeki
The error is pretty well explained
Have a look at what the --apache flag does in the documentation User Guide — Certbot 2.7.0.dev0 documentation
Also have a look at the functioning of the --webroot flag: User Guide — Certbot 2.7.0.dev0 documentation
The documentation provides a good mapping of authenticators and which challenges they support
https://certbot.eff.org/docs/using.html#getting-certificates-and-choosing-plugins
Feel free to ask questions however your command is flawed as it's trying to use two different authenticators (things that prove that you own the domain at the same time)
Andrei
I found a solution to my problem. It turns out nothing was wrong with my Apache2 configuration files. The problem was with two files, one located in /etc/apache2/sites-enabled and /etc/apache2/sites-available, both files were named 000-default-le-ssl.conf.
I’m unsure how these files got there, but deleting them then using sudo letsencrypt --apache fixed the problem. SSL is up and running on both my primary and sub-domains!
glad you got it sorted
btw - not to be picky but deleting the files below is to do with apache configuration files :smiley: files in those locations are used by apache when it loads.
Andrei
The -le is for “Let’s Encrypt”. Those files were previously created by Certbot!
So, it was probably a bug in how Certbot interacted with the existing configuration. I’m not sure exactly what the problem was without seeing the whole configuration.
