SOLVED:SSL for Godaddy
Hi guys,
Can you send me all the steps required to issue and install SSL on Godaddy shared hosting account?
I’m executing this script:
export GD_Key=“sdfsdfsdfljlbjkljlkjsdfoiwje”
export GD_Secret=“asdfsdafdsfdsfdsfdsfdsafd”
acme.sh --issue --dns dns_gd -d aa.com -d www.aa.com
And it works. But there are additional steps required in order to install the SSL.
After this command, I try this one:
acme.sh --install-cert -d example.com
–cert-file /path/to/certfile/in/apache/cert.pem
–key-file /path/to/keyfile/in/apache/key.pem
–fullchain-file /path/to/fullchain/certfile/apache/fullchain.pem
–reloadcmd “service apache2 force-reload”
But apache2 command is not found…
Can you send me all steps required?
Hi @s7ankoff
if you use a Godaddy shared hosting, I don't think you are able to install a certificate.
Ask Godaddy.
Read
Just solved my issue by reading posts…
Thanks anyway :)))
Ah, thanks, good to know.
I don’t use Godaddy, shared hostings normally don’t allow to script such things.
Looks like a good guide, thanks @s7ankoff. Didn’t know of that one. Bookmarked.
It also counters some of the arguments made in the Let’s Encrypt documentation about GoDaddy which @JuergenAuer posted earlier. Especially the cPanel script makes automation possible, which is great!
