Seting up NGINX and SSL with noip DDNS
My domain is: fargoparanormal.zapto.org
My web server is (include version): nginx with nextcloud 31.0.9 Snap
The operating system my web server runs on is (include version): Ubuntu 25.1.1
My hosting provider, if applicable, is: NoIP ddns
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Certbot classic 5.1
GNU nano 8.4 /var/log/letsencrypt/letsencrypt.log
2025-10-31 10:08:45,474:DEBUG:urllib3.connectionpool:http://localhost:None "GET /v2/connections?snap=certbot&interface=content HTTP/1.1" 200 97
2025-10-31 10:08:45,626:DEBUG:certbot._internal.main:certbot version: 5.1.0
2025-10-31 10:08:45,626:DEBUG:certbot._internal.main:Location of certbot entry point: /snap/certbot/5057/bin/certbot
2025-10-31 10:08:45,626:DEBUG:certbot._internal.main:Arguments: ['-v', '--preconfigured-renewal']
2025-10-31 10:08:45,626:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#nginx,Plu>
2025-10-31 10:08:45,640:DEBUG:certbot._internal.log:Root logging level set at 20
2025-10-31 10:08:45,640:DEBUG:certbot._internal.plugins.selection:Requested authenticator None and installer None
2025-10-31 10:08:45,642:DEBUG:certbot.plugins.util:Failed to find executable apache2ctl in PATH: /snap/certbot/5057/bin:/snap/certbot/5057/usr/bin:/usr/local/sbin:>
2025-10-31 10:08:45,643:DEBUG:certbot._internal.plugins.disco:No installation (PluginEntryPoint#apache): Cannot find Apache executable apache2ctl
File "/snap/certbot/5057/lib/python3.12/site-packages/certbot/_internal/plugins/disco.py", line 109, in prepare
self._initialized.prepare()
File "/snap/certbot/5057/lib/python3.12/site-packages/certbot_apache/_internal/configurator.py", line 360, in prepare
self._verify_exe_availability(self.options.ctl)
File "/snap/certbot/5057/lib/python3.12/site-packages/certbot_apache/_internal/configurator.py", line 478, in _verify_exe_availability
raise errors.NoInstallationError(
certbot.errors.NoInstallationError: Cannot find Apache executable apache2ctl
2025-10-31 10:08:45,771:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * nginx
Description: Nginx Web Server plugin
Hello @davolker1, welcome to the Let's Encrypt community. :slightly_smiling_face:
Please show the output of each of the following command sudo nginx -T that is a capital T
Edit
The HTTP-01 challenge states "The HTTP-01 challenge can only be done on port 80."
Thus access to Port 80 is required.
Best Practice - Keep Port 80 Open
And using the online tool Let's Debug yields these results https://letsdebug.net/fargoparanormal.zapto.org/2607289
