My domain is: tvt.pl
sudo certbot --apache --agree-tos --redirect -m admin@tvt.pl -d tvt.pl -d www.tvt.pl
Deploying certificate
Successfully deployed certificate for tvt.pl to /etc/apache2/sites-available/tvt.pl-le-ssl.conf
Successfully deployed certificate for www.tvt.pl to /etc/apache2/sites-available/tvt.pl-le-ssl.conf
Congratulations! You have successfully enabled HTTPS on https://tvt.pl and https://www.tvt.pl
My web server is (include version): Server version:
Apache/2.4.57 (Debian)
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
My hosting provider, if applicable, is: My private server with Comcast ISP
certbot 2.6.0
I got Certbot certificate to the domain and all works fine when my Debian server with Apache web server is connected directly to cable modem (Comcast provider), but when I connect my Debian server to router and the router to cable modem I am not able to reach tvt.pl domain at all.
All web browers says: Secure Connection Failed.
I need to say I have set up port 80, 22 and 443 forwarding on my router. My Debian server has ufw firewall with open ports 80, 22 and 443. All is working when server is directly connected to modem, but does not work when I add my router.
I have spend 3 days working on that and do not have more ideas what can be wrong. I will appreciate your help and time.
