myrkur.net
sudo certbot --apache -d myrkur.net -d www.myrkur.net
Unable to read ssl_module file; not disabling session tickets.
Enter email address (used for urgent renewal and security notices)
(Enter 'c' to cancel): linukongurinn@protonmail.com
https://letsencrypt.org/documents/LE-SA-v1.3-September-21-2022.pdf. You must
agree in order to register with the ACME server. Do you agree?
(Y)es/(N)o: y
Would you be willing, once your first certificate is successfully issued, to
share your email address with the Electronic Frontier Foundation, a founding
partner of the Let's Encrypt project and the non-profit organization that
develops Certbot? We'd like to send you email about our work encrypting the web,
EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: y
Account registered.
Requesting a certificate for myrkur.net and www.myrkur.net
Certificate is saved at: /usr/local/etc/letsencrypt/live/myrkur.net/fullchain.pem
Key is saved at: /usr/local/etc/letsencrypt/live/myrkur.net/privkey.pem
This certificate expires on 2023-06-08.
Deploying certificate
Successfully deployed certificate for myrkur.net to /usr/local/etc/apache24/extra/httpd-vhosts-le-ssl.conf
We were unable to find a vhost with a ServerName or Address of www.myrkur.net.
Which virtual host would you like to choose?
1: httpd-vhosts.conf | myrkur.net | | Enabled
2: httpd-vhosts-le-ssl.conf | myrkur.net | HTTPS | Enabled
Successfully deployed certificate for www.myrkur.net to /usr/local/etc/apache24/extra/httpd-vhosts-le-ssl.conf
Congratulations! You have successfully enabled HTTPS on https://myrkur.net and https://www.myrkur.net
NEXT STEPS:
- The certificate will need to be renewed before it expires. Certbot can automatically renew the certificate in the background, but you may need to take steps to enable that functionality. See User Guide — Certbot 2.4.0 documentation for instructions.
- Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
- Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
z@myrkur:~ $ httpd -v
Server version: Apache/2.4.55 (FreeBSD)
Server built: unknown
FreeBSD 13.1
my own
no
z@myrkur:~ $ certbot --version
certbot 2.1.0
..also:
z@myrkur:~ $ apachectl
AH00112: Warning: DocumentRoot [/usr/local/www/apache24/data/myrkur.net] does not exist
AH00526: Syntax error on line 13 of /usr/local/etc/apache24/extra/httpd-vhosts-le-ssl.conf:
SSLCertificateFile: file '/usr/local/etc/letsencrypt/live/myrkur.net/fullchain.pem' does not exist or is empty
If anyone is kind enough to help it would be appreciated.
Thanks
