Student infirmation system ssl setup
My domain is: oblsis.bilkent.edu.tr
The operating system my web server runs on is (include version): Apache
My hosting provider, if applicable, is:bilkent.edu.tr
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): yes
Hi @selcukcagan
checking your domain there is no older certificate. Port 80 is open and answers with the expected result http status 404 - Not Found ( https://check-your-website.server-daten.de/?q=oblsis.bilkent.edu.tr ):
So start with some basics:
Then select a client:
Checking /.well-known/acme-challenge/random-filename there is content:
Visible Content: Not Found HTTP 404 (GET /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de) [lib/base.php:1706] Base->error() [index.php:11] Base->run()
Perhaps you have to configure that system so the raw output of the validation file is sent.
