~/.secrets/certbot/ folder does not exist
My domain is: travagh.me
I ran this command: nano ~/.secrets/certbot/digitalocean.ini
It produced this output: [ Directory '/root/.secrets/certbot' does not exist ]
My web server is (include version): Unknown, running AdGuard Home
The operating system my web server runs on is (include version): Ubuntu 22.04 (LTS) x64
My hosting provider, if applicable, is: DigitalOcean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.6.0
I'm following the directions from here: Welcome to certbot-dns-digitalocean’s documentation! — certbot-dns-digitalocean 0 documentation
Performing 'cd ~/.secrets/certbot' give me the following error: -bash: cd: /root/.secrets/certbot/: No such file or directory
So it sounds like you need to create that directory if you want to edit the file in question.
With Linux, you can make use of the mkdir command to make new directories.
Also please note that the command snippets where you got the ~/.secrets/certbot from are just EXAMPLES as clearly stated at the top of the examples. So that means the commands are not necessarily a 1-on-1 fit for your specific situation.
I assumed from the instructions that it should exist. There is no indication of creating the directory, just the digitalocean.ini file within the directory.
As a wise man once said:
Assumption is the mother of all (...)
The command snippets are just examples. Documentation shouldn't need to spell out every small (and IMO obvious) detail. :slight_smile:
As they're just examples, you're free to put the digitalocean.ini anywhere you want, as long as it's SECURE :slight_smile: (i.e.: root readable and writable only). Heck, you don't even need to name it digitalocean.ini, you could name it bert_and_ernie.ini for all I care :stuck_out_tongue:
Thanks for your help :+1:
This is what I think @Osiris looks like now:
